Pyro, Steam
Khikmatillo
Hi Khikmatillo
Firstly you will need to close up you geometry for the sdf to work well in the sim, Try using a polyfill on the geo before turning it into sdf, or giving it some thickness on the walls of the kettle.
Also you don't need the collision geometry to be this precise, In you current setup it is set to be 10x more precise than you simulation, try setting it to a bigger value ( e.g. if your pyro sim is .01 (voxel size) the most precise you will need your collider sdf to be is .01, but feel free to set it to a bigger value like .1 since collision in your case doesn't need to be all that heavy to compute to get the good result )
This is my first post here, so I hope it helps :)
  On 6/15/2023 at 10:44 AM, Lazar Lukic said:
Hi Khikmatillo
Hi, Lazar Lukic,
Thank you for reply, I almost got the result
