gpapaioa Posted August 15, 2023 Share Posted August 15, 2023 Hello everyone. Is it possible to add particles to a new group as soon as they are advected e.g. from a volume? I want the particles to react differently as soon as they are advected. Thank you. Quote Link to comment Share on other sites More sharing options...
Librarian Posted August 16, 2023 Share Posted August 16, 2023 @gpapaioa This it's for 2d Advect on Gas-limit particles and it works if you change Dimension depending what you have in your scene, how you advecting? ..then you can also reference min max in from your(field's)center, volumes..endless Possibility .. Quote Link to comment Share on other sites More sharing options...
gpapaioa Posted August 16, 2023 Author Share Posted August 16, 2023 I am advecting with a custom vel vol, with popadvectbyvolumes. I had a thought: whenever a particle is advected, it could pick up an attribute from 0 to 1 (like attribopy in SOPs). And later with a POPwrangle, group the ones with 1. Need to research if this is possible in DOPs. Quote Link to comment Share on other sites More sharing options...
bengaet Posted August 16, 2023 Share Posted August 16, 2023 (edited) inside a sopsolver in your dopnet you could create an object merge to bring in your velocity field and check if the particle is inside the velocity field. v@vel = volumesamplev(1, 'vel', @P); you can also reduce it to a float by calculating the length of the vector f@speed = length(v@vel); you can then either use that attribute to gradually activate another force or use it to add particles to a group if(f@speed > 0){ @group_advected = 1; } Edited August 16, 2023 by bengaet Quote Link to comment Share on other sites More sharing options...
gpapaioa Posted August 17, 2023 Author Share Posted August 17, 2023 Fantastic thank you, will try it out Quote Link to comment Share on other sites More sharing options...
