Librarian Posted August 25, 2023 Share Posted August 25, 2023 Can't find how to make this Pattern on grid !!!hm Quote Link to comment Share on other sites More sharing options...
Aizatulin Posted August 25, 2023 Share Posted August 25, 2023 Here is an experimental approach pattern_divisions.hipnc Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted August 25, 2023 Share Posted August 25, 2023 Another approach. pattern.hip Quote Link to comment Share on other sites More sharing options...
Librarian Posted August 25, 2023 Author Share Posted August 25, 2023 @Aizatulin @konstantin magnus 1 Quote Link to comment Share on other sites More sharing options...
Librarian Posted August 25, 2023 Author Share Posted August 25, 2023 OK ! I really appreciate your time Thank You @Aizatulin and @konstantin magnus now we have endless patterns in diff Direction . with color. Next Didn't find How to make diff patterns only on Columns( Random patterns)?? pattern_divisionsWith color and diff Dir.hipnc Quote Link to comment Share on other sites More sharing options...
Aizatulin Posted August 26, 2023 Share Posted August 26, 2023 Sure regarding your second example with the colums, I wouldn't use division methods only. Maybe you try something dividing the polygons seperately and copy them onto a column grid (with variants) or with feedback loop, where you can check for intersections and mark already used parts. So you can build your division prim independently from the placement. So in fact you can probably do this without any divisions but if interested here is another modifiaction with a single step division method (you can play around with), where you can divide a polygon into two parts just using two (relative)vertices and two amount values. pattern_divisionsA.hipnc Quote Link to comment Share on other sites More sharing options...
Librarian Posted August 26, 2023 Author Share Posted August 26, 2023 @Aizatulin May you live to be 100 years old and more. 1 Quote Link to comment Share on other sites More sharing options...
Librarian Posted August 27, 2023 Author Share Posted August 27, 2023 @Aizatulin more ideas .Can be useful for someone . IdeaM.hiplc 2 Quote Link to comment Share on other sites More sharing options...
