Masoud Posted November 2, 2023 Share Posted November 2, 2023 Hi guys, I scattred several geometries (lines) using "Attribute From Pieces" + "Copy to points" SOPs on some animated points. The problem is, on the "Attribute From Pieces" SOP, when I set the mode to the "Cycle", everything is ok, but when I set it to the "Noise" mode, it starts to changing each piece's name over Time. (And when I use not-animated points everything is ok, too). How can I fix it? Thanks for helping. Attribute From Pieces.hip Quote Link to comment Share on other sites More sharing options...
Librarian Posted November 2, 2023 Share Posted November 2, 2023 Under location change to sourceprimuv Quote Link to comment Share on other sites More sharing options...
Masoud Posted November 2, 2023 Author Share Posted November 2, 2023 Thanks you. Quote Link to comment Share on other sites More sharing options...
