TheDude123 Posted January 12, 2024 Share Posted January 12, 2024 Hi, I've got a situation where I need to offset an attribute in time and I can't seem to figure it out. Example, Attribute 'foo' animates from 0-1 across 24 frames. However, it's offset per point, so each point arrives at 1 on different frames and all points are 1 by frame 24. I need 'foo' to animate from 0-1 across 48 frames (or some other arbitrary time frame), while maintaining each points individual offset. I essentially want to create a delay in the 'foo' attribute. Any suggestions, VEX or VOPs? Example file included. How far I got is in the VOP node. Thanks! attribute_delay_v001.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted January 13, 2024 Share Posted January 13, 2024 I replied here . Quote Link to comment Share on other sites More sharing options...
