RobiDoes3d Posted February 1, 2024 Share Posted February 1, 2024 (edited) Hey everybody, I'm trying to make a custom smoke solver. However, when I try to advect vel by itself it doesn't work as expected. I want the field to expand outward, like this: But it only expands to its boundary. like this: Does anyone know how to fix this? (without using divergence) advectingVel.hip Edited February 1, 2024 by RobiDoes3d Quote Link to comment Share on other sites More sharing options...
Librarian Posted February 2, 2024 Share Posted February 2, 2024 (edited) @RobiDoes3d In Houdini, the Gas Advect Node mircoslover can be used for advecting fields based on an existing field. If we have some interaction between fields, The Gas Calculate node can be used to copy information from one field to another. or use this method to blend in endless ways also not Gas advect field Node Edited February 2, 2024 by Librarian 2 1 Quote Link to comment Share on other sites More sharing options...
fencer Posted February 2, 2024 Share Posted February 2, 2024 gasresize should do the trick advectingVel_v02.hip 2 1 Quote Link to comment Share on other sites More sharing options...
RobiDoes3d Posted February 3, 2024 Author Share Posted February 3, 2024 @fencer Thanks, I never thought of using that node outside of a normal sim setup. @Librarian That level of control would be great, unfortunately, I still don't understand how you did it. How do @dest, @source, @blenda, and @blendb control the sim? Why is it only calculated on the 1st frame? ...If you haven't already deleted the .hip file, I would love to take a look at it Quote Link to comment Share on other sites More sharing options...
Librarian Posted February 3, 2024 Share Posted February 3, 2024 @RobiDoes3d I just combined those methods with this 3 days old post . Don't need to be on first Frame, it's Just Test. https://forums.odforce.net/topic/52695-how-can-i-use-the-microsolvers-to-resize-a-density-field-dynamically/#comment-240203 Quote Link to comment Share on other sites More sharing options...
Librarian Posted February 4, 2024 Share Posted February 4, 2024 and this file it's a Must for this stuff . simpleGasSolverInTenSteps.hipnc Quote Link to comment Share on other sites More sharing options...
