5DNick Posted February 16, 2024 Share Posted February 16, 2024 Dear Forumers, I thought my .hip was not necessary as there maybe an easy answer here I am missing. I have a pyro sim that seems to be cropped by the bake volume node. Why? This happens even when it is dense. I am thinking it's the bake node because if I display flag the pyro before it, I see the whole bounds (uncropped) and if I flag the bake then I see the cropping bound size that renders. Weirdly, and maybe showing it's NOT the bake node, if I bypass the bake and go to a material node with a karma pyro mat assigned to it, the cropping still renders! Anyway I am confused, although I bet there's a simple explanation. Thanks, Nick Quote Link to comment Share on other sites More sharing options...
5DNick Posted February 19, 2024 Author Share Posted February 19, 2024 So I decided to attach a .hip as I got no reply to this. Probably always a good idea from the start I imagine. Frame 1004 from FAR_TEST_CAM shows clear cropping of the top of the pyro. What's up?! DRONEPYRO_v063_FORODFORCE.hiplc Quote Link to comment Share on other sites More sharing options...
5DNick Posted February 20, 2024 Author Share Posted February 20, 2024 So I've been fiddling about attempting to solve this. I have a new question from what I've found: that it seems to be cropping when FIRE is enabled. Why is this? Any kind of fix? Quote Link to comment Share on other sites More sharing options...
fencer Posted February 21, 2024 Share Posted February 21, 2024 Not sure I understand, what I see is two different initial shapes for density and temperature, probably this causes the issue. pyrobakevolume/volumevisualization could clamp final output by density or so. Quote Link to comment Share on other sites More sharing options...
5DNick Posted February 21, 2024 Author Share Posted February 21, 2024 (edited) 4 hours ago, fencer said: Not sure I understand, what I see is two different initial shapes for density and temperature, probably this causes the issue. pyrobakevolume/volumevisualization could clamp final output by density or so. YES! Thankyou fencer. I believe I discovered this by fiddling as you typed this! Spooky! But nice to have confirmation. PS: AND/OR combined with my density not being sourced from the initial bounds? I'm still SLIGHTLY confused because I would think the dynamic resizing would fix this. Edited February 21, 2024 by 5DNick update Quote Link to comment Share on other sites More sharing options...
