Need help to rig a spring around a piston
Hi, I'm recently starting to learn rig on houdini, everything's going good until I tried to rig a spring around a piston, I don't know what I should parent it to, or what constraint to use for it to follow the movement of the piston, and still being able to make it look at to an extremity. Can someone help me clarify what should I do ? The final goal is to make the spring extend as the piston does.
  • 8 months later...
