vel control
Hey guys.
 how can I control vel like this picture? I used minpos but particles stick to the surface and my work hasn't 3d dimension. I need to add a random speed, direction, and noise to the particles and have dimension.
my particles move is very flat.
_Hole.hipFetching info...
Edited by mohammadzand
There are 2 option you can consider:
1. Do a box with your hole mesh hallow inside present as divergence ehich will help you to pressure the stream into the area you want (look for divergence with smoke you will ubderstand)
2. You cand build gradient field from density or surface collision then snap the position of the oncurrent stream into where you want
Addtional information, use your hole center at position where all N is destination, make the velocity to pull all those direction to hole, convert to a vel field you want
https://youtu.be/wABDw7cgumM?si=O1_HssyfAYw-TlaK
  • 4 weeks later...
Expand
appreciate you.
