realflowbow Posted June 7, 2024 Share Posted June 7, 2024 Hello I am trying to achieve something similar to the example video where a scoop comes in and scoops out some ice cream. I've only seen this done once recently and it looked like the person used grains, but it didn't look as real as what I'm going for. Does anyone have any ideas on how best to approach this? Is grains the only option besides using a bend node and keyframe animating? Thank you for your time in advance! scoop.mp4 1 Quote Link to comment Share on other sites More sharing options...
hannes603 Posted June 7, 2024 Share Posted June 7, 2024 try vellum grains. untitled.mp4 vellum_grains_ice_cream.hip 2 Quote Link to comment Share on other sites More sharing options...
anthonymcgrath Posted June 10, 2024 Share Posted June 10, 2024 On 6/7/2024 at 2:33 PM, hannes603 said: try vellum grains. untitled.mp4 vellum_grains_ice_cream.hip 682 kB · 8 downloads thats gorgeous - right off the bat - fantastic! 1 Quote Link to comment Share on other sites More sharing options...
anthonymcgrath Posted June 10, 2024 Share Posted June 10, 2024 On 6/7/2024 at 2:33 PM, hannes603 said: try vellum grains. untitled.mp4 vellum_grains_ice_cream.hip 682 kB · 9 downloads @hannes603 so i had a twiddle and just played with the scoop animation but i seem to be hitting an issue... in that the icecream seems to stop being scooped midway through - why would that be do you think? Is the same setup as yours with half the grains for speed - but you can see in the gif i made its like the icecream stops getting "collected" ? Quote Link to comment Share on other sites More sharing options...
hannes603 Posted June 10, 2024 Share Posted June 10, 2024 19 minutes ago, anthonymcgrath said: @hannes603 so i had a twiddle and just played with the scoop animation but i seem to be hitting an issue... in that the icecream seems to stop being scooped midway through - why would that be do you think? Is the same setup as yours with half the grains for speed - but you can see in the gif i made its like the icecream stops getting "collected" ? substeps maybe? 1 Quote Link to comment Share on other sites More sharing options...
anthonymcgrath Posted June 10, 2024 Share Posted June 10, 2024 @hannes603 - so having a twiddle with the sleeping values seemed to help it out - i think some very slow moving grains just decided "hey we moved.. but only a bit... so now we going back to sleep" 1 Quote Link to comment Share on other sites More sharing options...
slap Posted August 1, 2025 Share Posted August 1, 2025 (edited) That’s a great topic! I recently worked on a strawberry ice cream bowl render (attaching an image for reference). For the scoop animation, maybe try blending a metaball setup with some noise-driven displacement for a soft, creamy texture. The key is keeping the surface slightly irregular — just like real ice cream scooping. Looking forward to seeing more results from this! Edited August 15, 2025 by slap reference add Quote Link to comment Share on other sites More sharing options...
