L-system Generations Stamping Tricks?
peliosis
I bumped on some strangeness here.
L-sysytem stamping works great with many parameters, like eg. ball scale.
-I created a sphere, added transform sop and in uniform scale wrote : stamp("../lsystem2","myscale",1)
-I put myscale into l-system>funcs >leaf param A
- the rule contains : J(1,,1/g) where 1/g is stamped scale parameter.
Ofcourse it works, no problem.
So if this is correct, why I cant stamp generations parameter of another l-system used as leaf???
With the very same setup? :blink:
It is weird I know, David Gary covers that problem in his second lsystem dvd, so you may have a look there. He builds HDA to overcome this problem, very useful.
pozdr.
kuba
Ha! Great! I love to hear I was not wrong.
On my way to buy that DVD ;)
Dzieki Kuba!
I solved it.
It now offsets local animation of growing leaves based on point number and template l-system point count. Quite easy stamping "start" parameter from shift chop.
Will attach hip after making it pretty enough B) .
