I need to create some attributes to use with the Attribute Interpolate SOP..!
Masoud
Hi guys,
As you know, the "Attribute Interpolate" SOP needs two attributes called "sourceprim" and "sourceprimuv", which the "Scatter SOP" can create them.
I would like to create them myself, so in a point wrangle, I tried to use these codes:
i@sourceprim = 0;
v@sourceprimuv = primuv(0, "P", @primnum, @P);
If you take a look at my file, you will see that it works in a strange way, so how can I fix it?
Thanks for helping.
Scatter_01.hipFetching info...
