caskal Posted September 27, 2024 Share Posted September 27, 2024 Hi Magicians, Quick question, I have an Arch shaped door, filled with flip, that I need to map it. I ended up using a solution that is not ideal, basically I did the sim in the UV to POS instead of the actual 3D arch. There's any way, to have the sim in the actual arch, and then be able to unrwap it to flat uv pos? Thanks! houdini_YoxruHzjFB.mp4 Quote Link to comment Share on other sites More sharing options...
hannes603 Posted September 29, 2024 Share Posted September 29, 2024 use prim uv and xyzdist to create the P value vor an pc open. untitled.mp4 flip_water_prim_uv_xyz_dist_uv_sample_vop.hip 1 1 Quote Link to comment Share on other sites More sharing options...
caskal Posted October 9, 2024 Author Share Posted October 9, 2024 @hannes603 legend! thanks so much for the help and file, its super helpful, appreciate it! Cheers Quote Link to comment Share on other sites More sharing options...
EdwinFumano Posted April 7 Share Posted April 7 @caskal this looks very interesting. just out of curiosity, what would you use this for? cheers! Quote Link to comment Share on other sites More sharing options...
