Parasites - Procedurally Growing Organism ?
How would you grow a parasite ?
- I am going to "try" to create an organism which is something like parasite or some kind of fungi [located on trees]
- The thing is that before I get started working on this effect, I wanted to take some advices and suggestions from you guys who are interested.
- I was thinking about using L-Systems to get the effect but I am sure that there are other ways too.
- I also will need to create a custom shader in VOPs to get the realistic effect.
Any Suggestions, Ideas, or references about how to create the system and the shader would be appreciated.
Thanx in advance.
* I am putting some references to illustrate the effect that I need to achieve.
References [ BBC- Planet Earth Series ]
Video File:
Parasite - BBC Planet Earth
Images:
good question!
Looking forward to see you approach. You mind if I grow something on my own?
Need to get rid of these boxes somehow ...
Maybe this book helps:
http://www.amazon.com/Growth-Form-Complete...6891650-2892932
Haven't read it, though.
Georgh
Edited by rdg
  jeffrey.higgins said:
as far starting with this, i would go old reliable metaballs, lots of them!!
animating the weights and converting to geo once you've gotten you're shape right!!
good luck!
Thanks for the tip jeffrey. I am gonna try animating the weight
cheers
  old school said:
Looks like branching structures to me = lsystems or trailing particles.
at the moment I am experimenting with l-system
But u r right trailing particles will also work I am gonna give a shot.
apart from that the shading scares me a little bit.
because I haven't touched subsurface scattering before.
need to check the sss posts :rolleyes:
cheers
  jjstanley said:
For the shader you may want to look at some of the wrok by the winner of the last Houdini contest, Serg. You can see his project at http://www.sidefx.com/index.php?option=com...opic&t=6420. He had some great ideas that may come in handy for you.
thanks jjstanley,
I have already checked Serg's sss solution and its really clever [ respect ] :)
at the moment I am doing some experiments with Mario's SSS shader which is perfect.
Besides, render times are a bit heavy so maybe I might need to use Serg's solution.
By the way I am using Marc's [correct me if I am wrong] pcplastic shader as well, which helps a lot with the internal colours
Thanx again for the link
this is the first shading test.
cheers
SEQUENCE TEST - Flicker
I made a sequence test with Mario's SSS shader.
However, it is somehow flickering. looks like a lighting artifact but the light is fixed
I think the Problem will be point cloud sequence
I am posting the parameters, light position and the video.
If anyone has an idea what the problem is...
need help
cheers
Flicker Artifact !!! - Video File
flicker.movFetching info...
SC_Shot_01
Shader Parameters (MultipleScattering)
Shader Parameters (SingleScattering)
PointCloud Parameters (Cloud Generation)
PointCloud Parameters (Density Estimate)
