Nico D. Posted July 13, 2007 Share Posted July 13, 2007 I'm trying to copy the animation from same object on different scenes. Now I exported a bclip from chops, then I import it on the new scene and export from chops to the same object. But now I need to change the animation and all channels are "overriden" and cannot find how to "bake" that exported channels onto my object. Quote Link to comment Share on other sites More sharing options...
sibarrick Posted July 14, 2007 Share Posted July 14, 2007 Why not just copy and paste the channel directly rather than going through chops? Quote Link to comment Share on other sites More sharing options...
Nico D. Posted July 14, 2007 Author Share Posted July 14, 2007 Why not just copy and paste the channel directly rather than going through chops? Copying channels between different scenes is not working. I have to merge the old one and then copy channels between objects on the same scene. I also try to import an animation clip into the scoped channels at the channel editor but gives an error when importing. Quote Link to comment Share on other sites More sharing options...
Mr.Ed Posted September 11, 2007 Share Posted September 11, 2007 was there any solution to this? I am having a similar problem but I am also transfering animation from rigs in H8 and rigs in H9. Quote Link to comment Share on other sites More sharing options...
michael Posted September 11, 2007 Share Posted September 11, 2007 you could try using opscript -c Quote Link to comment Share on other sites More sharing options...
old school Posted September 11, 2007 Share Posted September 11, 2007 You can use the pose library tool. Select the object you want to export. In the channel list, make sure you have scoped all the channels you want to export. Open the help browser. Go to the Pose Library. (see below for H8 and H9 instructions) Press Save Pose. Follow directions and save the pose. Note: You can also save an animation by specifying a range instead of a single frame range. Save your scene and close. Open up the other scene. Select the target object. Open the Pose Library and apply the pose. To open the Pose library in H8, open the help and in the Go Menu at the very top left side, select "Pose Library" In H9, that widget didn't make it (so far) so you have to type in the path: file:///opt/hfs9.0.715/houdini/html/poselib/index.html where file:///opt/hfs9.0.715 is the path to your houdini installation. Quote Link to comment Share on other sites More sharing options...
