How To Scatter Points?
Well... That was a bad question :rolleyes: Another one is: should I write my own function for this kind of job or there is something ready to use in HDK?
I don't know how much of the scatter SOP is exposed in the HDK, but I would try it out first.
if you want your custom op to scatter points and then do something with them, then (assuming the scatter SOP does what you want), I would just have your custom op do the extra bit you want and then wrap the 2 node (or possibly more) into an otl.
just my 2cents!!
good luck,
jeff
just my 2cents!!
good luck,
jeff
I did what I want to do now some time ago using HDA but it's too easy and not as interesting as digging of HDK :lol:
