polterizer Posted March 21, 2025 Share Posted March 21, 2025 (edited) Hello I have configured Deadline to work between Windows and Linux, it works perfectly submiting as single cache, thanks to Igor Zanic who has helped me the linux part. I only have a problem with submiting the wedges, I am including a screenshot, I don't know if this method is the correct for both windows and linux workers, it only works for me on Windows, the linux one is getting issues on log, I don't know how to solve it. maybe anyone know? also i attach the hip thanks Carlos new_wedge.hip Edited March 21, 2025 by polterizer Quote Link to comment Share on other sites More sharing options...
tamagochy Posted March 21, 2025 Share Posted March 21, 2025 First of all you need to check log or post it here. We have windows farm so I cant check it on my side. Quote Link to comment Share on other sites More sharing options...
polterizer Posted March 21, 2025 Author Share Posted March 21, 2025 hi, thanks for answer, i think its complicated because the pdg is exe , needs make conversion scripts for linux. for now im trying the old method wedge of OUT. will see Quote Link to comment Share on other sites More sharing options...
polterizer Posted March 21, 2025 Author Share Posted March 21, 2025 I configured as old wedge method but only works if i do "render wedge" from wedge sop see the screenshot. submit deadline from deadline node is not working. i paste the log: Error ======================================================= Error: Caught exception: Failed to modify node or parameter because of a permission error. Possible causes include locked assets, takes, product permissions or user specified permissions at Deadline.Plugins.PluginWrapper.RenderTasks(Task task, String& outMessage, AbortLevel& abortLevel) ======================================================= Type ======================================================= RenderPluginException ======================================================= Stack Trace ======================================================= at Deadline.Plugins.SandboxedPlugin.d(DeadlineMessage bgt, CancellationToken bgu) at Deadline.Plugins.SandboxedPlugin.RenderTask(Task task, CancellationToken cancellationToken) at Deadline.Slaves.SlaveRenderThread.c(TaskLogWriter ajx, CancellationToken ajy) ======================================================= Log ======================================================= 2025-03-21 21:09:32: 0: Loading Job's Plugin timeout is Disabled 2025-03-21 21:09:32: 0: SandboxedPlugin: Render Job As User disabled, running as current user 'Administrator' 2025-03-21 21:09:33: 0: Executing plugin command of type 'Initialize Plugin' 2025-03-21 21:09:33: 0: INFO: Executing plugin script 'C:\ProgramData\Thinkbox\Deadline10\workers\polter-FX\plugins\67ddd57fd14c05041c32456c\Houdini.py' 2025-03-21 21:09:33: 0: INFO: Plugin execution sandbox using Python version 3 2025-03-21 21:09:33: 0: INFO: About: Houdini Plugin for Deadline 2025-03-21 21:09:33: 0: INFO: The job's environment will be merged with the current environment before rendering 2025-03-21 21:09:33: 0: Done executing plugin command of type 'Initialize Plugin' 2025-03-21 21:09:33: 0: Start Job timeout is disabled. 2025-03-21 21:09:33: 0: Task timeout is disabled. 2025-03-21 21:09:33: 0: Loaded job: old_wedge - /out/wedges{WEDGE #0} (67ddd57fd14c05041c32456c) 2025-03-21 21:09:34: 0: Executing plugin command of type 'Start Job' 2025-03-21 21:09:34: 0: DEBUG: S3BackedCache Client is not installed. 2025-03-21 21:09:34: 0: INFO: Executing global asset transfer preload script 'C:\ProgramData\Thinkbox\Deadline10\workers\polter-FX\plugins\67ddd57fd14c05041c32456c\GlobalAssetTransferPreLoad.py' 2025-03-21 21:09:34: 0: INFO: Looking for legacy (pre-10.0.26) AWS Portal File Transfer... 2025-03-21 21:09:34: 0: INFO: Looking for legacy (pre-10.0.26) File Transfer controller in C:/Program Files/Thinkbox/S3BackedCache/bin/task.py... 2025-03-21 21:09:34: 0: INFO: Could not find legacy (pre-10.0.26) AWS Portal File Transfer. 2025-03-21 21:09:34: 0: INFO: Legacy (pre-10.0.26) AWS Portal File Transfer is not installed on the system. 2025-03-21 21:09:34: 0: Done executing plugin command of type 'Start Job' 2025-03-21 21:09:34: 0: Plugin rendering frame(s): 1-120 2025-03-21 21:09:34: 0: Executing plugin command of type 'Render Task' 2025-03-21 21:09:34: 0: INFO: Set HOUDINI_PATHMAP to {"K:/":"K:/", "/mnt/_houdini/":"K:/", "$HOUDINI":"K:/"} 2025-03-21 21:09:34: 0: INFO: Redshift Path Mapping... 2025-03-21 21:09:34: 0: INFO: source: "K:\" dest: "K:\" 2025-03-21 21:09:34: 0: INFO: source: "/mnt/_houdini/" dest: "K:\" 2025-03-21 21:09:34: 0: INFO: source: "$HOUDINI" dest: "K:\" 2025-03-21 21:09:34: 0: INFO: [REDSHIFT_PATHOVERRIDE_FILE] now set to: "C:\ProgramData\Thinkbox\Deadline10\workers\polter-FX\jobsData\67ddd57fd14c05041c32456c\RSMapping_tempuexP90\RSMapping.txt" 2025-03-21 21:09:34: 0: INFO: Starting Houdini Job 2025-03-21 21:09:34: 0: INFO: Stdout Redirection Enabled: True 2025-03-21 21:09:34: 0: INFO: Stdout Handling Enabled: True 2025-03-21 21:09:34: 0: INFO: Popup Handling Enabled: True 2025-03-21 21:09:34: 0: INFO: QT Popup Handling Enabled: False 2025-03-21 21:09:34: 0: INFO: WindowsForms10.Window.8.app.* Popup Handling Enabled: False 2025-03-21 21:09:34: 0: INFO: Using Process Tree: True 2025-03-21 21:09:34: 0: INFO: Hiding DOS Window: True 2025-03-21 21:09:34: 0: INFO: Creating New Console: False 2025-03-21 21:09:34: 0: INFO: Running as user: Administrator 2025-03-21 21:09:34: 0: INFO: Executable: "C:\Program Files\Side Effects Software\Houdini 20.5.445\bin\hython.exe" 2025-03-21 21:09:34: 0: CheckPathMapping: Swapped "K:/utiles/old_wedge.hip" with "K:\utiles/old_wedge.hip" 2025-03-21 21:09:34: 0: INFO: Argument: "C:\ProgramData\Thinkbox\Deadline10\workers\polter-FX\plugins\67ddd57fd14c05041c32456c\hrender_dl.py" -f 1 120 1 -g -d /out/wedges -tempdir "C:\ProgramData\Thinkbox\Deadline10\workers\polter-FX\jobsData\67ddd57fd14c05041c32456c\0_tempSVFNs0" -arnoldAbortOnLicenseFail 1 "K:/utiles/old_wedge.hip" 2025-03-21 21:09:34: 0: INFO: Full Command: "C:\Program Files\Side Effects Software\Houdini 20.5.445\bin\hython.exe" "C:\ProgramData\Thinkbox\Deadline10\workers\polter-FX\plugins\67ddd57fd14c05041c32456c\hrender_dl.py" -f 1 120 1 -g -d /out/wedges -tempdir "C:\ProgramData\Thinkbox\Deadline10\workers\polter-FX\jobsData\67ddd57fd14c05041c32456c\0_tempSVFNs0" -arnoldAbortOnLicenseFail 1 "K:/utiles/old_wedge.hip" 2025-03-21 21:09:34: 0: INFO: Startup Directory: "C:\Program Files\Side Effects Software\Houdini 20.5.445\bin" 2025-03-21 21:09:34: 0: INFO: Process Priority: BelowNormal 2025-03-21 21:09:34: 0: INFO: Process Affinity: default 2025-03-21 21:09:34: 0: INFO: Process is now running 2025-03-21 21:09:35: 0: STDOUT: Detected Houdini version: (20, 5, 445) 2025-03-21 21:09:35: 0: STDOUT: ['C:\\ProgramData\\Thinkbox\\Deadline10\\workers\\polter-FX\\plugins\\67ddd57fd14c05041c32456c\\hrender_dl.py', '-f', '1', '120', '1', '-g', '-d', '/out/wedges', '-tempdir', 'C:\\ProgramData\\Thinkbox\\Deadline10\\workers\\polter-FX\\jobsData\\67ddd57fd14c05041c32456c\\0_tempSVFNs0', '-arnoldAbortOnLicenseFail', '1', 'K:/utiles/old_wedge.hip'] 2025-03-21 21:09:35: 0: STDOUT: Start: 1 2025-03-21 21:09:35: 0: STDOUT: End: 120 2025-03-21 21:09:35: 0: STDOUT: Increment: 1 2025-03-21 21:09:35: 0: STDOUT: Ignore Inputs: True 2025-03-21 21:09:35: 0: STDOUT: No output specified. Output will be handled by the driver 2025-03-21 21:09:35: 0: STDOUT: Driver: /out/wedges 2025-03-21 21:09:35: 0: STDOUT: Input File: K:/utiles/old_wedge.hip 2025-03-21 21:09:35: 0: STDOUT: Begin Path Mapping 2025-03-21 21:09:36: 0: STDOUT: b'' 2025-03-21 21:09:36: 0: STDOUT: b'' 2025-03-21 21:09:36: 0: STDOUT: Setting variable "HIP" to K:\utiles 2025-03-21 21:09:36: 0: STDOUT: Setting variable "HIPFILE" to K:\utiles/old_wedge.hip 2025-03-21 21:09:36: 0: STDOUT: End Path Mapping 2025-03-21 21:09:36: 0: STDOUT: ROP type: wedge 2025-03-21 21:09:36: 0: STDOUT: Error: Caught exception: Failed to modify node or parameter because of a permission error. Possible causes include locked assets, takes, product permissions or user specified permissions 2025-03-21 21:09:36: 0: STDOUT: Traceback (most recent call last): 2025-03-21 21:09:36: 0: STDOUT: File "C:\ProgramData\Thinkbox\Deadline10\workers\polter-FX\plugins\67ddd57fd14c05041c32456c\hrender_dl.py", line 559, in <module> 2025-03-21 21:09:36: 0: STDOUT: renderNode.parm("f1").set(startFrame) 2025-03-21 21:09:36: 0: STDOUT: File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.445/houdini/python3.10libs\houpythonportion\Parm.py", line 97, in set 2025-03-21 21:09:36: 0: STDOUT: self._set(value) 2025-03-21 21:09:36: 0: STDOUT: File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.445/houdini/python3.10libs\hou.py", line 71834, in _set 2025-03-21 21:09:36: 0: STDOUT: return _hou.Parm__set(self, *args) 2025-03-21 21:09:36: 0: STDOUT: hou.PermissionError: Failed to modify node or parameter because of a permission error. Possible causes include locked assets, takes, product permissions or user specified permissions 2025-03-21 21:09:37: 0: Done executing plugin command of type 'Render Task' Quote Link to comment Share on other sites More sharing options...
paranoidx Posted March 22, 2025 Share Posted March 22, 2025 I don't read in detail but in Linux use "/" but not "\" for path separator I see a Japan user use V-Ray Deadline node but not the one ship with Deadline, maybe your Redshift need it too Quote Link to comment Share on other sites More sharing options...
tamagochy Posted March 24, 2025 Share Posted March 24, 2025 First need to check paths because '\' not work in linux env. Second its permission error. Quote Link to comment Share on other sites More sharing options...
polterizer Posted March 24, 2025 Author Share Posted March 24, 2025 thanks but im not using the linux part for now, meaning the wedge sop (old) is no working in windows deadline. will figure it out no worries, thanks! Quote Link to comment Share on other sites More sharing options...
tamagochy Posted March 25, 2025 Share Posted March 25, 2025 With windows PDG wedges works ok for us, I'm not sure deadline support old wedges as it is without some prep work Quote Link to comment Share on other sites More sharing options...
