Point Normals From Scatter Points
Rafal123
Normals in PointSOP are computed from a faces. If there is no faces I suppose normals are {0,0,0} or nothing is set (can't check now).
To have normals on scattered points you should have normals on points in source geometry.
cheers,
sy.
thanks people!
works great... it even works with no attribTransfer connected, I found it's a matter of connection order
[CIRCLE]
[sKIN]
[POINT]
[sCATTER]
in this setup it works, before I had SKIN after POINT :)
p.s
can somebody explain why it ain't work when POINT is before SKIN? When I show info on those three(POINT SKIN SCATTER) H shows that all of them have 1 point attribute N[3] , why it should be transfered?
Edited by Rafal123
  • 1 month later...
