patis Posted July 14 Share Posted July 14 Hello, I'm very new to Houdini and still trying to get familiar with the UI and workflow. I've finally managed to get to the rendering stage, but the result looks much rougher and lower quality than what I see in the viewport preview… I'm not sure what I'm doing wrong. I've attached the scene file for reference. Thank you. houdini question.zip Quote Link to comment Share on other sites More sharing options...
RealYooRee Posted Friday at 01:14 AM Share Posted Friday at 01:14 AM First of all you can't expect opgl viewport look would be the finnal render look especially involved with lighting and materials, you should tweak the material and lighting settings according to the render reulst and you can tell the differences from the refelctions. the render one is more physically correct. That is beauty of path traced rendering. Quote Link to comment Share on other sites More sharing options...
hannes603 Posted 16 hours ago Share Posted 16 hours ago better render it through mplay or send a batch render if you want the full quality Quote Link to comment Share on other sites More sharing options...
