Guide Geometry Color?
I've got some custom guide geometry for a Pop node I'm working on. Is there a way to change the color of the guide geometry? I found the GOP_Guide class which allows for some customization (line width, drawing styles..).. but don't see a control for ogl color. There is an option to set it as OP_GUIDE_ONE or OP_GUIDE_TWO, each has it's own hard coded color, but that's as much flexibility as I can find.
Thanks
D
  • 4 months later...
Hi Daniel did you ever solve this?
I'd like to do something similar in sops with some coloured guide geometry. I see it done in dops so it must be possible somehow.
Would adding Cd primitive or point attribute do the trick?
I never did solve this. I don't think I every ping'd Sesi support directly, it would be nice to do. I have a custom softbody node I wrote with 5 different kinds of spring constraints and I wanted to color each differently, but right now I'm just living with them all the same and provide a toggle for each to display the various types
D
D
BTW, if you guys do figure this out, I'd still like to know. I'm not sure if prim colors would work Jason, maybe in the absence of Cd it picks a default color, but with it you can override.. hmm.. have to try it (that'd be too sensible!)
D
D
I think I suggest it because IIRC there was some mention of this in the distant past... memory ...fading..
  • 1 month later...
