Rafal123 Posted November 27, 2007 Share Posted November 27, 2007 how Mantra use $WIDTH for curve rendering? let say I have a field of grass which edge is displaced, I wanna add noise to the edge during Mantra rendering, can noise be added to polystrips' edge ? Quote Link to comment Share on other sites More sharing options...
rdg Posted November 27, 2007 Share Posted November 27, 2007 (edited) how Mantra use $WIDTH for curve rendering?let say I have a field of grass which edge is displaced, I wanna add noise to the edge during Mantra rendering, can noise be added to polystrips' edge ? I only know $width as a point attribute. If you have 'enough' points on a line you can have a 'noisy' line. like: ($PT / $NPT) * rand($PT) * $my_noise_strength But maybe I misunderstand: "field of grass which edge is displaced". Georg BTW: there is also a $ORIENT - which allows you to twist the grass ... Edited November 27, 2007 by rdg Quote Link to comment Share on other sites More sharing options...
crunch Posted November 27, 2007 Share Posted November 27, 2007 how Mantra use $WIDTH for curve rendering?let say I have a field of grass which edge is displaced, I wanna add noise to the edge during Mantra rendering, can noise be added to polystrips' edge ? And you can attach a displacement shader which displaces the grass toward the centerline... Not sure off the top of my head, but I expect it would include dPds Quote Link to comment Share on other sites More sharing options...
symek Posted November 27, 2007 Share Posted November 27, 2007 And you can attach a displacement shader which displaces the grass toward the centerline... Not sure off the top of my head, but I expect it would include dPds Not really. There are U and V definied during render a curve WIDTH. You can refer to it in both shading context and displacement context as you would refer to position on a normal surface. Quote Link to comment Share on other sites More sharing options...
Rafal123 Posted November 27, 2007 Author Share Posted November 27, 2007 simply said: I just don't wanna have geo grass in my scene/view coz it's too heavy to work smooth, thats' why I need it only in Mantra, also noisy curve needs enough points which again means too heavy scene, what I wanted is to pass width(you right RDG) attribute to Mantra and use also to displace the edge of the polystrip Quote Link to comment Share on other sites More sharing options...
Jason Posted November 28, 2007 Share Posted November 28, 2007 This all should work fine, yeah. You might also be interested in the "orient" vector attribute. This defines the orientation of the ribbon which might work well for grass (since grass is flat, unlike hair which has a circular profile). Often you can just generate N and swap it to orient in an Attribute SOP. You can use s and t global variables for the parametric coordinates for the sake of surface and displacement. Also, you should be able to use the Fur system to perform render-time population of grass blades from a few guide blades. 1 Quote Link to comment Share on other sites More sharing options...
Rafal123 Posted November 28, 2007 Author Share Posted November 28, 2007 many thanks people, Jason: cool tip with FUR, must check that Quote Link to comment Share on other sites More sharing options...
