Flickering in flip simulation surface
Hello everyone, I hope you are well, what happens is that I have this problem with a flip, I create the surface with particle fluid surface and the surface looks like this, it seems that parts of the liquid are joining and separating making it look very ugly, I did not add any filtering to the particle fluid surface node, I hope someone can explain to me how to solve this, the particle separation I have is 0.006
  • 2 weeks later...
if your particles are not flickering then most likely due to the meshing process. Trying to reduce the "Influence Scale" parameter on the particle fluid surface SOP or turn off "Dilate" and "Erode" on the filtering tab if you are giving it very high value.
