Randomizing Color of Grid Points
platypus
ok. extremely newbie-ish question here, but here goes...
I am starting with a grid, appending a point SOP. I am then attempting to randomize the color of each point on the grid, in order to copy a geometry to the points and have them inherit the random color.
any suggestions? am I going about this properly at all?
many thanks in advance.
well, copy stamping would be the way to do it, but if you've never done it, it can be tricky to figure out. I don't know if there's any good tutorials on it out there....
anyway, here's a hipfile, cause that's faster than trying to explain it :)
things to look out for are the param expressions in the point sop under the sphere, and the point expressions in the copy sop.
color_stamp.hip.gz
Alternatively you could randomise the point colours in the point sop and just click on the "Copy Template Point Attributes" in the point SOP. That will make all the copied spheres inherit all attributes from the template, including colour. :)
For the randomise, (it may be in that hipfile already, but its quick to explain) just make sure you use a different seed for each point ie.
rand($PT) in the $CR field, rand($PT*2) in the $CG and rand($PT*4) in the $CB field. The numbers don't matter, as long as the value is different. $PT will change the seed per point.
Hope this helps
Marc
:o
at some point you realize your thinking is too complicated, and you have to sit back and remember the simple things :P
Thanks Mark!
Jens
P.S. if you want a quick example of copystamping as well as using point expressions, check out my file anyways ;)
much and many thanks to all three of you!!!
Marc - i have used your pointers and it worked out great. so simple, and i have been beating my head against the monitor for hours on this. heheh. the more familiar I become with Houdini, the more i love its (deceptive) simplicity - maybe straightforward approach is a better way to put it. I guess it is all just a matter of getting to know your way around, the operators.
I will check out the hip file next.
you guys are tremendous!
thanks again.
