evgen Posted February 5, 2008 Share Posted February 5, 2008 Hello, How to cut object like at this picture - it seems that it is cutted by curves or something like that Can i use for cookie-node 2d-primitives (grid, extruded line without caps and thickness) ? Maybe i should use another way ? thanks Quote Link to comment Share on other sites More sharing options...
SpencerL Posted February 5, 2008 Share Posted February 5, 2008 (edited) I think that is cut using a grid with noise applied to it in one input of a cookie SOP and the Vase in the other input. Did you need to cut your geometry using curves? If so, I would reccommend trying your suggestion of extruding the curve so you have a plane and then wire that into the cookie SOP. Edited February 5, 2008 by SpencerL Quote Link to comment Share on other sites More sharing options...
petz Posted February 6, 2008 Share Posted February 6, 2008 if you need to cut your geometry by curves, you can project them onto the surface using the project-sop. with the trim-sop you can, as the name suggests, trim your geometry in pieces. the thing is that you have to convert the geometry to nurbs for using trim. it works fine for simple geometries like your vase. if the geometry is more complex, the result could be somehow weird and unusable. hope that helps, petz Quote Link to comment Share on other sites More sharing options...
evgen Posted February 7, 2008 Author Share Posted February 7, 2008 Thank you. very usefull info! Quote Link to comment Share on other sites More sharing options...
