Coz_y_not Posted April 7 Share Posted April 7 (edited) It looks like velocity is not continuously injected, only in the 1st frame 1001. hip file attached. it's the default flip tank from the shelf tool to which I added ocean spectrum, and a grid to visualise. Frame 1032 there is still something happening from earlier velocities, about 100 frames later it's already dead by frame 1240, it's almost dead quiet. am I doing something wrong, how to Make sure velocity is continuously injected, not just the 1st frame 1001? flip_from_ocean.hiplc Edited April 7 by Coz_y_not Quote Link to comment Share on other sites More sharing options...
haggi Posted April 9 Share Posted April 9 Did you simply create a ocean from the shelf tools to see how it is done correctly? 1 Quote Link to comment Share on other sites More sharing options...
David Tom Posted April 15 Share Posted April 15 On 4/9/2026 at 1:01 PM, haggi said: Did you simply create a ocean from the shelf tools to see how it is done correctly? same question! Quote Link to comment Share on other sites More sharing options...
