Safe Frame Display Options error
rob
The Safe Frame ( display options ) Does not move to fit any other aspec ratios like 1024 x 576 or any HD settings . Is this a bug with 9.1 ? If so is there any way to fix this via a home made solution as its pretty dam important to have !
R
I think the Safe Frame support hasn't been updated for HD. The only solution you have in the short term is to utlize the Mask support (like the Mask Overlap SOP) features on the Camera.
However, I'd report this to SESI as I'm sure it's not a terribly hard fix for them.
  • 3 weeks later...
I have been trying to get this to work . I wanted to create the lines for the safe frame and the title safe but when using the mask overlay I am having to move it around by hand to get it lining up in the camera view, not a good way. Can anyone suggest a way to get this working ?
R
