Challenge 1 - Bridge Of Cards (apprentice) - eetu
eetu
Hi!
I wanted to make a bridge that would have some dynamics, so I set my sights on an indianajonesy suspension bridge.
I spent quite a lot of time trying to figure out how to create a variable amount of two-way wire-wire and wire-rdb constraints, as I wanted to keep the bridge procedural.
..Didn't figure it out, so ended up with a branching wire "cheat". I wanted to make a partial "chainlink" setup with the cards, but now they are just copied onto the wires.
This still looks ugly, but I'm posting it here to force myself to finish it :)
At the very least I want to go thru the material/map randomization.
eetu.
ee_bridge1.mpg
Smells like minimum effort, but here's the same with randomized card textures.
Some overlapping, but no time left today.
Any hints on the issue of making a variable number of two-way constraints?
With some of the constraint nodes I can create variable number of constraints, but they all get constrained to the same target.
Creating nodes with a script would probably do it, but is there a better way?
ee_bridge2b.mpg
