How to get a system time in HScript?
hoknamahn
Hi guys!
I have one question: how i can get system time from HScript? I want to get start time and end time of any animation and calculate average fps of system.
I thought what backward quotes must work in Houdini like in Perl but it's not working (at least in the Windows)! :( (see below)
set start_time = `system(time /T)`;
Who can answer on question: how to get system time and assign it to variable? :-(
the unix command from hscript lets you run shell commands, for example
unix date
would work but houdini isn't aware of whatever the date command outputs.
still you can do a
unix "echo %TIME% > c:/temp/start_time.txt"
play the animation, blah blah then
unix "echo %TIME% > c:/temp/stop_time.txt"
or append with >>
(the double quotes are there to prevent hscript from interpreting anything inside them, well i think variable expansion would happen)
do the rest in perl and call it again using the unix command like
unix perl blah.pl
hum well i'm sure there are 10^6 better ways to do it
  • 17 years later...
  • 2 years later...
On 8/22/2020 at 12:45 PM, hved said:
YYMMDD format
`substr(system("cmd /C date /T"), 12, 2)``substr(system("cmd /C date /T"), 4, 2)``substr(system("cmd /C date /T"), 7, 2)`
This is great!! Have been looking for this for a while now!! Is it possible to add current time in hours and minutes as well? :)
