Is there like a node which is similar to FFD in 3D-Max?
in houdini it[s called lattice, and has two modes
first is lattice and it uses a boxlikeshape as control objec. the points method is like a cage or warp deform and it can use any mesh or point cloud as deformer. the help should help You further
mh, not sure if i really know what the ffd does :)
Edited by sanostol
use any shape and its deformed version to reshape ur target
in the below example, i used a box to act as a boundary to the teapot/platonic solid.
so the process can be explained as:
The object u want deformed in input 1 of the lattice
the box - unedited in input 2
the box - edited in input 3
the difference between input 2 and input 3 will be applied to input 1.
one thing to note - the divisions of the lattice and the divisions of the box must match.
hope this is what u were wondering about.
:blink:
