nvidia + rh8 stuff
plan9
http://www.nvidia.com/view.asp?IO=linux_di...y_ia32_1.0-4191
I made a dual boot system on my Athlon XP 2200+ with Geforce 4 Ti 4600 video card running Windows XP Pro and Red Hat Linux 8.
I configured the dual boot using the LILO boot loader. All that is fine.
However, I am having problems getting the NVIDIA drivers installed. I consulted the nvidia website. I read the TEXT file install instructions.
I ran NVCHOOSER to see which GLX and which kernel drivers I should install. It said to use the following
NVIDIA_GLX-1.0-4191.i386.rpm
NVIDIA_kernel-1.0-4191.rh80up_2.4.18_18.8.0.athlon.rpm
using rmp -ivh
I also did this in Text mode, not in X windows.
In addition I edited the XFREE86CONFIG got rid of load "dri", there wasnt a load "glcore" to get rid of as the instructions suggested. In addition, I and load "nvidia" in place of the "nv"
Now I can't get back into X windows, and I got a module error when trying to rpm the above drivers.
Has anyone had any experience in dealing with Red Hat 8 and Nvidia?
I have succesfully done this with a dual boot PIII and RH 7.3 in the past.
Any suggestions would be appreciated.
Thanks
greets!
these are the errors:
xsetroot: unable to open display
xrdb: cant open display
xset: unable to open display
ksplash: cannot connect to xserver
kdeinit: aborting $DISPLAY is not set
warning: connect() failed connection refused
ksmserver: cannot connect to xserver
error: cant open display
error: cant contact kdeinit
NVIDIA(0): failed to initialize the nvidia kernal module
fatal IO error 104 Connection reset by peer on X server ":0.0"
I did try to force install, but tells me it is already installed... *grumble*
thanks for the feedback so far! ;)
Hey forum guy with flying pig avatar, :D
Did you check the "/var/log/XFree86.0.log" file to see which XF86config file is used to start the X server? Perhaps you edited the wrong config file?
If you edited the wrong config file, please make a copy of the correct config file before editing.
You have fun now because I know how fun it is to edit the XF86config/XF86config-4 file!!! :P
Cheers!
steven
Which version of the Kernel are you running? I'm running 2.4.18-26.8.0 and I had buildproblems with the NVidia Source RPM. I got fed up with RPM and downloaded the tarballs and compiled from scratch.
Mats
  matsbt said:
Mats
Source RPMs are evil! Especially in combination with RedHat 8.0's RPM/packaging system, which has it's pro's aswell though...
Try the good old gzipped tarball. It worked without any problems for me!
I had the exact same problem under Mandrake 8.2. The solution is to manualy add the nvidia kernel module to the module config files.
Here's my /etc/modules file:
# /etc/modules: kernel modules to load at boot time.
# This file should contain the names of kernel modules that are
# to be loaded at boot time, one per line. Comments begin with
# a `#', and everything on the line after them are ignored.
joydev
nvidia
scsi_hostadapter
Here's my /etc/modules.conf file:
alias usb-interface usb-uhci
alias sound-slot-0 emu10k1
probeall scsi_hostadapter ide-scsi
alias /dev/nvidia* nvidia
alias eth0 ne2k-pci
I think that all you need to do is add the lines where nvidia is mentioned to the coresponding files on your system.
I hope this solves your problems.
Goran
