exhelp list? Print?
Hi all,
I am trying to print all the list of expressions which is whoen when I type "exhelp" in text port.
When I type this, I get only list of the names of the expressions..
Is there any way to get the explanations of all the expressions in one page?
So, I can copy them to MS Word or ant other text sofeware to print out the whole information.
Thanks,
-Jae
Hi all,
Thanks,
-Jae
Here: http://www.sidefx.com/docs/houdini9.1/expressions
You could also make some trick with piping help from texport to a file.
Thanks for quicking replying!
It seems like it shows only how it works, but is there any way to see not only explanation but
like this :
float fit01 (float num, float newmin, float newmax)
USAGE
fit01(num, newmin, newmax)
Returns a number between newmin and newmax that is relative to num
in the range between 0 and 1. If the value is outside the 0 to 1
it will be clamped to the new range.
EXAMPLES
| fit01(.3,5,20)=9.5
RELATED
* fit
* fit11
* fit10
thanks,
-j
Hi all,
Thanks,
-Jae
Hey Jae Yoo,
Do this in the textport:
foreach i ( `execute("exhelp")` )
echo $i >> c:/exhelp.txt
end
The above should print out all the help into a text file. The only issue is it's not alphabetical.
Cheers!
steven
...or little longer in Python :huh: : (but saves *all help content)
functions= hou.hscript("exhelp")[0].split()
help_ = ["".join(hou.hscript("exhelp %s" % f)) for f in functions]
file = open("./help.txt", "w").writelines(help_)
file.close()
cheers,
sy.
Edited by SYmek
Hey Jae Yoo,
end
Cheers!
steven
Hi, Thanks for replying.
It works, but it saves only the expression names..
what I want to print is detail information of each expressions explanation.
For example, for fit,
float fit (float num, float oldmin, float oldmax, float newmin, float newmax)
USAGE
fit(num, oldmin, oldmax, newmin, newmax)
Return a number between newmin and newmax that is relative to num
in the range between oldmin and oldmax. If the value is outside
the old range, it will be clamped to the new range.
EXAMPLES
| fit(3,1,4,5,20)=15
RELATED
* fit01
* fit11
* fit10
I wanted this information for every each expressions to print.
Thanks!
Edited by Jae Yoo
Doh! I gave you the wrong line.
It should be:
 exhelp $i >> c:/exhelp.txt
 end
Cheers!
steven
And people say hscript is complicated and tedious compared to Python...! :o
Edited by SYmek
