houdini cop and shake?
HI all,
I rendered a sequence using image plane to make zDepth and I bring the rendered zDepth sequence using COP file node.
It seems right with the COP file node, but not with shake.
I opened up the sequence using shake in terminal. and it does not show me anything.
Thanks,
-Jae
shake doesnt bring in .pic files. What image format are you using?
I am using Tiff format.
The funny thing is when I loaded the sequence in Shake(which I execute), and loaded the images with "file in" node, the images looked right.
But, When I opened the sequence files with Terminal and type shake " <sequence name> ", it showed me black images..
Thanks,
-Jae
Thanks,
-Jae
This seems to me like its a shake issue you are having and not a houdini issue. What is the synatx/command you are entering in the command line? It should probably be something like:
shake myImgSeq.#.tif -t 1-100x1
I am typing just
Thats it.
What is "-t 1-100x1" doing??
Thanks,
-Jae
  • 1 month later...
  • 2 weeks later...
