How do I get obj's velocity in Vop Vex Surface?
Hi all,
I have an animated character and he kicks and punches.
I would like to get the character's prim velocity or point velocity in vop vex, so I can multiply it to opacity.
What I am trying to do is faster velocity area gets high opacity and lower velocity area gets low opacity.
Here is the set-up I have done for now..
What should I add to it?
Thanks a lot! :lol:post-3325-1217547675_thumb.jpg
Edited by Jae Yoo
Hi all,
Do you want to drive the refraction intensity (Kt) with the magnitude of the velocity? Or do you want to blend two materials - glass and something else based on the magnitude of velocity?
Hi, Jason.
Refraction strength and opacity value.
Thanks,
Hi, Jason.
Thanks,
Okay, take a look at this simple example. I've driven three shaders by the 'v', which I've calculated in SOPs with a Trail SOP.
Mixing shaders, ramping off Kt, and fading off the object (by reducing Of and Cf by the v magnitude).
The Fit Range VOP in there is just to map the v magnitude to a decent 0-1 range. This will vary a lot based on your scene and your needs.
drive_material_by_v.hipnc
Hi, Jason.
Thanks a lot!
I got one more additional question,
My animated character seems like it does not have big difference between the faster area and the slower area.
I mean, there is difference between them.. but Its really slight.
Is there any way to exaggerate the value like smaller value 1 -> 1.324 and stronger value 10 -> 223.34?
Thanks,
-j
Hi, Jason.
Thanks a lot!
Thanks,
-j
you can use a fit function to expand your magnitude range. You need to enter the original min and max values of your mag followed by your new min and max values.
fit($YOUR_MAG, 1, 10, 1.324, 223.34)
