interactive keyed obj
cloudfx
Hey Jae
depends how the object has been animated
- if its a deforming mesh, u can bring in a static object, but specify that its a deforming object on the static object DOP,
- if has been animated at object level, u can use the OBJ Position DOP, and point it too the object at object level, to extract the animation and bring that into dops.
does this work for u? :blink:
Hey Jae
Thanks for quick replying,
So, after I bring the animated object using OBJ Position DOP, what solver should I use?
Thanks!
If you have other RBD objects colliding with this deflector, you should just use a RBD Solver.
Cheers!
steven
It is an animated object( not a deforming mesh) and I bring them with OBJ Position DOP, and connect it to the RBD solver.
RBD solver said the input is the wrong type.
What should I fix..? hmm
Thanks!
Thanks!
Have you created the actual RBD object? I think the OBJ position DOP only brings in transform data and applies it to your RBD.
Put down a RBD object DOP with unchecked create active object above your OBJ position DOP.
Edited by mawi
