Rvb Posted September 25, 2008 Share Posted September 25, 2008 Hi, normally I would post on the website on 3dbuzz but I want to get involved with both sites because you guys rock aswel! I have a little knowledge with Houdini but I want to get better. In the attachment you will find my current project. I would like to model a house with houdini but I cant figer out how I would create windows / doors. Wat is the best way to do this? Thank you Quote Link to comment Share on other sites More sharing options...
stevenong Posted September 25, 2008 Share Posted September 25, 2008 Hi, You can position boxes where you want the windows, make sure they intersect through the walls and merge the boxes together with a Merge SOP. Next, append a Cookie SOP and connect the Merge SOP to the first input and the walls to the second. Select A Minus B or B Minus A to see the result. Alternatively, you can do PolySplits, Dissolve, Polyknits etc to create the windows. Hope others have more ideas. Cheers! steven Quote Link to comment Share on other sites More sharing options...
rdg Posted September 25, 2008 Share Posted September 25, 2008 (edited) stevenong said: Hope others have more ideas. You could project a grid onto a another grid, trim the result offset it and skin both copies ... Surprisingly complex network, probably forgot to set HOUDINI_DISABLE_COMPLEXITY=1 ... Nurbs not dead! ... and welcome ! wall.hipFetching info... Edited September 25, 2008 by rdg Quote Link to comment Share on other sites More sharing options...
Rvb Posted September 26, 2008 Author Share Posted September 26, 2008 Thank you all for the replies. The cookie way is the easiest way. rdg could you explain why you work with so many nodes? Thank you both Quote Link to comment Share on other sites More sharing options...
rdg Posted September 26, 2008 Share Posted September 26, 2008 Rogier Verbrugge said: Thank you all for the replies. The cookie way is the easiest way. rdg could you explain why you work with so many nodes? Thank you both Because ... I couldn't use less ... I guess you could use less, but I wasn't able to. Sorry. Quote Link to comment Share on other sites More sharing options...
Rvb Posted October 2, 2008 Author Share Posted October 2, 2008 Haha oke I'm working on a watch right now for my final school project I will post some pictures in time Quote Link to comment Share on other sites More sharing options...
Jason Posted October 2, 2008 Share Posted October 2, 2008 Rogier Verbrugge said: rdg could you explain why you work with so many nodes? The ends justify the means Quote Link to comment Share on other sites More sharing options...
