Netvudu Posted October 3, 2008 Share Posted October 3, 2008 Hi there. What I want is to use a proxy geometry to view in the viewport, but to render geometry at render time in place of that proxy stuff. How is this done? I have a nice scene of pillars that Gallenwolf posted to help, but he uses copies at object level, placed individually, while I want to substitute a la Andy Boyd, this is using a proxy geo for the copy SOP but rendering another thing. I thought copying an object merge of a geometry which pointed itself to the hires one through the procedural shader would be enough, but it Quote Link to comment Share on other sites More sharing options...
Allegro Posted October 3, 2008 Share Posted October 3, 2008 (edited) I know I could instance but that Edited October 3, 2008 by Allegro Quote Link to comment Share on other sites More sharing options...
stevenong Posted October 3, 2008 Share Posted October 3, 2008 Hi netvudu, I've attached a hip file that's similar to what you described - instancing delayed loaded objects. To test, please go into the teapot object and display the File SOP once to write out the geometry then render. Hope it helps. Cheers! steven teapot_delayed_load.zip Quote Link to comment Share on other sites More sharing options...
Netvudu Posted October 4, 2008 Author Share Posted October 4, 2008 (edited) Hey, thanks for this Steven. It Edited October 4, 2008 by Netvudu Quote Link to comment Share on other sites More sharing options...
ihab Posted October 5, 2008 Share Posted October 5, 2008 hey, check out this SESI presentation and sample files. LINK you'll find everything you need in there. Cheers Quote Link to comment Share on other sites More sharing options...
Netvudu Posted October 6, 2008 Author Share Posted October 6, 2008 wow, that Quote Link to comment Share on other sites More sharing options...
JoshJ Posted October 20, 2008 Share Posted October 20, 2008 I have a piece of geometry with different materials on different parts, and I'd like to instance the whole piece of geometry as a delayed load procedural. Do I need to break up the individual parts into different instances? Otherwise, how can I get different materials on the different parts of a single object that is instanced? Quote Link to comment Share on other sites More sharing options...
cloudfx Posted October 26, 2008 Share Posted October 26, 2008 I have a nice scene of pillars that Gallenwolf posted to help, Hi there, Is there any link to Gallenwolf's scene files that I can use to learn and study? Thank you, -j Quote Link to comment Share on other sites More sharing options...
Netvudu Posted October 28, 2008 Author Share Posted October 28, 2008 Hi there. It Quote Link to comment Share on other sites More sharing options...
