Fran Posted August 25, 2010 Share Posted August 25, 2010 Would be good to have some light here about how SOHO creates the IFD. One of the good things of instancing is that you don't have to put your instanced geo in the IFD/RIB file, just the points, and the instanced geo once. So I don't really understand why SOHO takes much time to do it. Have a look at the test file I created. Output the "instance" and "points" Mantra node and compare the ifd. Each instance has to create the transformation matrix and write each attribute like the shader etc. Only this part fits in 192 lines. Now look at the points and you'll see it fits in 30 lines only. The reason is because each attribute name is define at the beginning of the block and a bunch of value are put one after the other. It even looks like there are some sort of clever string recognition. It defines every different string and further refer to which index it correspond for each point. That's my explanation of why it is slow but I think Soho add an other level load just because it's Python. That's why I'm looking forward to test the clusterThis tool. François instance_soho_v001.hip Quote Link to comment Share on other sites More sharing options...
pclaes Posted August 26, 2010 Share Posted August 26, 2010 One of the good things of instancing is that you don't have to put your instanced geo in the IFD/RIB file, just the points, and the instanced geo once. So I don't really understand why SOHO takes much time to do it. I'm still not too fond of having all those points in the ifd. Tweak the lights and you have to rewrite you ifd :/ I actually wrote a post last weekend on this stuff: http://www.peterclaes.be/blog/?p=34#more-34 Quote Link to comment Share on other sites More sharing options...
kubabuk Posted November 18, 2010 Share Posted November 18, 2010 Has anyone tried to compile the code on H11? Make is prompting a bunch of errors due to changes in the HDK and I was wondering if anyone tried to workaround it by defining HDK_RELAXED_GB in make? Unfortunately I couldn't find in docs any example how this definition should look like, so any help is more then welcome. Cheers, kuba Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted February 6, 2011 Share Posted February 6, 2011 New version for H11: http://www.digitalcinemaarts.com/dev/clusterThis/ I'm still supporting H9.5 too as there's a number of people still needing it for older pipelines. Most of the mods were for H11 compatibility, but also factored out some redundant code (more to do there) and fixed the exit processing. I've built about a half dozen fairly complex mantra procedurals over the last year and oh boy is it getting fun. Since it's easier to put all the features into the code when you're getting paid to do it, unfortunately open source freebies often don't the same care and feeding. So, this version was going to have LOD support, multi-frame file geo instancing (for "walk cycles"), much more CVEX support and ... wait for it ... fully threaded. But, as I said, time has been very tight this last number of months so I hope to have these features in the next major update, before SIGGRAPH I hope. All the above features have been deployed successfully in a fairly rigorous production environment. Take care, Mark P.S. Oh, and I've got a *bunch* of samples to put up on the web for your viewing pleasure, soon, oh soon. Quote Link to comment Share on other sites More sharing options...
Jason Posted February 7, 2011 Share Posted February 7, 2011 Great stuff, Mark! And let me plant a little seed too -- because our "crowd" procedural here supports many of these types of features and so we did this: we wrote the corresponding GR_RenderHook which draws the procedural geometry in the OpenGL viewport. This results in the user being able to see what he'll be rendering without the weight of having to pass around any of that geometry in SOPs. Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted February 7, 2011 Share Posted February 7, 2011 Great stuff, Mark! And let me plant a little seed too -- because our "crowd" procedural here supports many of these types of features and so we did this: we wrote the corresponding GR_RenderHook which draws the procedural geometry in the OpenGL viewport. This results in the user being able to see what he'll be rendering without the weight of having to pass around any of that geometry in SOPs. Oh now you went a did it! I hadn't thought of that and now it will sit in my brain and germinate! Just checked the docs for the GR_RenderHook class, I'll have to give that a whirl. That is after finishing the rest of the mods though ... those darn attribute code changes are all over the place! Mark Quote Link to comment Share on other sites More sharing options...
kubabuk Posted February 8, 2011 Share Posted February 8, 2011 (edited) Nice, long awaiting, eventualy is here! Great news, Mark. Cheers, Kuba PS. Would like to see at some point, some day a masterclass from SESI regarding HDK.... Edited February 8, 2011 by kubabuk Quote Link to comment Share on other sites More sharing options...
pclaes Posted February 13, 2011 Share Posted February 13, 2011 This is great! I come back from holiday and get this little knowledge bomb to browse through . Thanks for your work and for sharing! Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted February 13, 2011 Share Posted February 13, 2011 This is great! I come back from holiday and get this little knowledge bomb to browse through . Thanks for your work and for sharing! Cool. There's more H11 mods coming soon, I haven't gotten rid of all the castAttribute() stuff yet. Enjoy! Mark Quote Link to comment Share on other sites More sharing options...
lisux Posted February 15, 2011 Share Posted February 15, 2011 Cool. There's more H11 mods coming soon, I haven't gotten rid of all the castAttribute() stuff yet. Enjoy! Mark Good done Mark, too much people still using the old method to deal with attributes, the new one is much better and a little faster. Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted February 15, 2011 Share Posted February 15, 2011 Good done Mark, too much people still using the old method to deal with attributes, the new one is much better and a little faster. Hi Pablo! Been a long time! I haven't done any performance comparisons but will give it a try as I've got two version I'm supporting, H9.5 and H11. There's still more mods to do, almost done, doing testing today. Will post later today probably. Take care, Mark Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted February 16, 2011 Share Posted February 16, 2011 Version 1.5.3 is online. All H11 changes are done, lots of redundant code removed. http://www.digitalcinemaarts.com/dev/clusterThis/index.html A few more bug fixes are next, then the last roll out of new features. Have fun, Mark Quote Link to comment Share on other sites More sharing options...
lisux Posted February 16, 2011 Share Posted February 16, 2011 Hi Pablo! Been a long time! I haven't done any performance comparisons but will give it a try as I've got two version I'm supporting, H9.5 and H11. There's still more mods to do, almost done, doing testing today. Will post later today probably. Take care, Mark Hey Mark, yep too much time Well, I noticed some improvements using the new mthods for attributes, but the improvemetn is really tiny, so not sure it you will get a better perfomance. Anyway I prefer the new method, is more clear and clean than before Quote Link to comment Share on other sites More sharing options...
Fran Posted June 26, 2011 Share Posted June 26, 2011 (edited) My Windows compilation nightmares are back. Even though I was able to compile in H10, I'm not able to do it in H11. Anyone has managed to do it? If yes, is there a particular procedure? I tried with hcustom under the Houdini shell and with Cygwin and neither work. I haven't tried with MakeFile because with my previous compilation test on H10 I haven't been able to use it so I thought hcustom is still the best thing to do. Mark told me the following variables are not set properly but I set them and it's still not working. When I use cygwin and source the houdini_setup_bash, these are set automatically. setenv HOUDINI_MAJOR_RELEASE 11 setenv HOUDINI_MINOR_RELEASE 0 Thanks guys! François Edited June 26, 2011 by Fran Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted June 26, 2011 Share Posted June 26, 2011 You need to use the Makefile ... else, you'll have to build the compile command(s) manually. Quote Link to comment Share on other sites More sharing options...
Fran Posted July 3, 2011 Share Posted July 3, 2011 I've finally managed to compile it for Windows. Here's the dll for 11.0.581 and the Makefile I used to compile it. For some reasons the forum doesn't allow me to upload files with certain extensions nor without extension so you'll have to rename the Makefile.txt to Makefile and VRAY_clusterThis.txt to VRAY_clusterThis.dll The hardest part is still to get a hand on the non-available-anymore compiler Visual Studio 2005 and add the two service packs to allow it to compile 64-bit. Thanks Mark again. Francois Makefile.txt VRAY_clusterThis.txt Quote Link to comment Share on other sites More sharing options...
Fran Posted July 5, 2011 Share Posted July 5, 2011 I've started to make some test with clusterThis. I want to use it especially for instancing geometry. I see I can use the N vector to orient the geometry but it doesn't seem to make use of the Up attribute nor rot to have full control on orientation. Is there any other way to do it? Francois Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted July 5, 2011 Share Posted July 5, 2011 I've started to make some test with clusterThis. I want to use it especially for instancing geometry. I see I can use the N vector to orient the geometry but it doesn't seem to make use of the Up attribute nor rot to have full control on orientation. Is there any other way to do it? Francois Hi Francois, I've had that on my list of additional attributes to add for some time, it will be in the next release. Depending on if your shader uses N or not, I've overridden N with the Up vector and vica versa, also did so with velocity. Problem is that there's a price to pay for using more attributes and in other mantra procedurals I've written I use a little more logic (more code too) to trim the number of attributes sent to mantra. There's a bit of it in the way I handle the attributes for the CVEX function calls. This very reason is why I'm almost done with another stripped down cluster DSO for point instancing only, plus there's a huge difference in the "deferred instancing" overhead vs. instancing geo all at once. --Mark Quote Link to comment Share on other sites More sharing options...
Fran Posted July 5, 2011 Share Posted July 5, 2011 I'm trying motion blur too and I've got something wrong with the motion blur. If you look at the attached file and render with the switch inside geo1 to 0 and 1, you'll see what I mean. It's as if the velocity attribute is transformed in rotation by the N attribute. Also, maybe I missed that information somewhere but is it possible to have a different object instanced per point, i.e. to be able to set the geo_file per instance point? Thanks Francois clusterThis_motionBlurTest_v01.hip Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted July 5, 2011 Share Posted July 5, 2011 I'm trying motion blur too and I've got something wrong with the motion blur. If you look at the attached file and render with the switch inside geo1 to 0 and 1, you'll see what I mean. It's as if the velocity attribute is transformed in rotation by the N attribute. Also, maybe I missed that information somewhere but is it possible to have a different object instanced per point, i.e. to be able to set the geo_file per instance point? For file instancing, use the deformation motion blur. There isn't a string point parm to select file geo, I had that in there for another show but never put it in the open source version. I don't see any difference in motion blur when changing N (using deformation/geometry motion blur). --Mark Quote Link to comment Share on other sites More sharing options...
