sky Posted April 4, 2003 Share Posted April 4, 2003 Hi there Is there a way to adjust memory buffer or cache size of background image sequence which is loaded into RAM ? Thanks Quote Link to comment Share on other sites More sharing options...
Jason Posted April 4, 2003 Share Posted April 4, 2003 Since it's run through COPs, perhaps you can increase the Settings>Main Preferences>Compositing>Cache Size option? Just a guess, but it may help.. try it and tell us if thats correct. Quote Link to comment Share on other sites More sharing options...
edward Posted April 4, 2003 Share Posted April 4, 2003 If you hit 'd' while in the cop viewer, there's also some more settings in there you can play with. Quote Link to comment Share on other sites More sharing options...
puma.snyder Posted April 4, 2003 Share Posted April 4, 2003 Just a guess as well, but maybe setting the texcache is of any help. Just type "help texcache" in your textport. Quote Link to comment Share on other sites More sharing options...
sky Posted April 5, 2003 Author Share Posted April 5, 2003 Hi All It's good idea. I loaded background image sequence in viewport (SOP, Object) directly from file option instead of COP. Thanks for good idea. I will try it later and tell you. Thanks Quote Link to comment Share on other sites More sharing options...
sky Posted April 18, 2003 Author Share Posted April 18, 2003 Thanks for Jason, puma.snyder, edward I tested it with COP, texcache option. When I use it with COP, Cache Size option enable realtime playback image sequence in RAM. But I tried it with texcache, I don't know how can I change Max Cache Memory. BTW, I got it with COP's cache option. Thanks Quote Link to comment Share on other sites More sharing options...
