Segmentation Fault.........
hi
does anyone know what causes "Segmentation Fault"??
i sometime encounter this error when saving file or switching between operators, esp to COPs.....will be prompt when COPs trying to re-cook the image.
is it bec of my setting or hardware?? anyone of u also got this problem also??
thanx! :)
If you are on support, best to send an example file or a description of the repeatable problem on to support. If this is apprentice, then send it to the apprentice forum.
A segmentation fault is also known as a core or core dump. This is generally caused by uninitialized or garbage memory that is created and/or used by Houdini or other applications. Generally if houdini seg faults, it is houdini's fault. If you get a blue screen of death, that is generally an OS Windows problem (graphics drivers like to do this).
