ivan Posted January 26, 2009 Share Posted January 26, 2009 has anybody used the makefiles that ship with Houdini? I can't seem to get 'em to work. Quote Link to comment Share on other sites More sharing options...
rdg Posted January 26, 2009 Share Posted January 26, 2009 has anybody used the makefiles that ship with Houdini? I can't seem to get 'em to work. What platform? I used hcustom with good results on suse 10.3 There was also a discussion on the SESI-List recently about windows vs makefiles ... but I'm not sure ... Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted January 26, 2009 Share Posted January 26, 2009 has anybody used the makefiles that ship with Houdini? Yes, I've been including the bundled "Makefile.linux" without any problems, though 99% of what I build are VEX dso's which make very light use of the HDK (some of the UT_* classes and not much else). I've tested on Suse10.3 (64-bit) and Suse11.1 (32-bit). On Suse11.1 I had to install gcc4.2.1 separately as it comes with gcc4.3.2, I believe, and the HDK expects 4.2.1 (mostly because it includes some deprecated libs, which are no longer there in 4.3.2), but otherwise, everything seems to be fine. No idea about Windows or OSX though. Quote Link to comment Share on other sites More sharing options...
ivan Posted January 26, 2009 Author Share Posted January 26, 2009 I must admit, I'm pretty feeble on these types of issues; I am having trouble on the most basic level. I copied the Makefile.linux to Makefile. If I run hcustom SOP_Flatten.C I get a compiled SOP, all happy like. if I run make SOP_Flatten.C make: Nothing to be done for `SOP_Flatten.C'. if I run make SOP_Flatten it doesn't find any of the $HT/include/ headers... Yes, I've been including the bundled "Makefile.linux" without any problems, though 99% of what I build are VEX dso's which make very light use of the HDK (some of the UT_* classes and not much else). I've tested on Suse10.3 (64-bit) and Suse11.1 (32-bit). On Suse11.1 I had to install gcc4.2.1 separately as it comes with gcc4.3.2, I believe, and the HDK expects 4.2.1 (mostly because it includes some deprecated libs, which are no longer there in 4.3.2), but otherwise, everything seems to be fine. No idea about Windows or OSX though. Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted January 26, 2009 Share Posted January 26, 2009 I must admit, I'm pretty feeble on these types of issues; I am having trouble on the most basic level.I copied the Makefile.linux to Makefile. if I run make SOP_Flatten.C make: Nothing to be done for `SOP_Flatten.C'. I believe the intent behind the makefiles that ship with Houdini is that you'll include them in your own project's Makefile -- i.e: they're not meant to be used directly as they don't define any targets, they just define the flags needed to build the different kinds of houdini objects: $OBJFLAGS (for compiling object files) $DSOFLAGS (for linking shared libs -- a.k.a: "dso" files) $SAFLAGS (for compiling + linking stand-alone apps) Then, in your project's Makefile, you can include one of these toolkit makefiles and define your own targets using those variables. For example, let's say you copy SOP_Flatten.C and SOP_Flatten.h to some directory. Then create a Makefile (in the same directory) with something like this inside it: # Include the toolkit's makefile include $(HT)/makefiles/Makefile.linux # Override optimizer settings, if you want # OPTIMIZER = -O2 # Define some compiler-related stuff #CC = /opt/gcc/4.2.1/bin/c++ CC = c++ LINK = $(CC) TAGINFO = $(shell (echo -n "Compiled on:" `date`" by:" `whoami`"\n$(SESI_TAGINFO)") | sesitag -m) # Set the source files. This assumes that each *.C file in the curr dir # is the source for a different .so -- adjust to taste OPS = $(wildcard *.C) # Output path for built ops OUTDIR = . # Define .o, .so, and any dependency files (based on the value of $OPS above) OBJFILES = $(OPS:%.C=%.o) DSOFILES = $(OBJFILES:%.o=$(OUTDIR)/%.so) DEPFILES = $(OBJFILES:%.o=%.d) # Include directories ($HT should point to the toolkit's install dir) INCDIRS = -I./ -I$(HT)/include # Extra objects to link with LNKOBJS = # Extra library paths LIBDIRS = #e.g: -L/path/to/mylibs -L/path/to/boost # Extra libraries LIBS = #e.g: "-lkewl" will look for "libkewl.so(.a)" in $LIBDIRS # Some flags for building dependencies... MAKEDEP = cpp -MM -MF $@ DEPWFLAGS = -Wall -W -Wno-parentheses -Wno-sign-compare -Wno-reorder \ -Wno-uninitialized -Wno-unused DEPDEFS = -DMAKING_DEPS DEPFLAGS = $(ARCHDEFS) $(DEPDEFS) $(VEXINC) $(INCINC) $(DEPWFLAGS) # Flags for building objects MYOBJFLAGS = $(INCDIRS) $(OBJFLAGS) -DMAKING_DSO $(TAGINFO) # Flags for linking MYLINKFLAGS= $(SHAREDFLAG) $(DSOFLAGS) #------------------------------------------------------------------------ # You should be able to leave the rest alone #------------------------------------------------------------------------ all: $(DEPFILES) $(OBJFILES) $(DSOFILES) .PHONY: all .SUFFIXES: %.d: %.C @echo Building dependencies for $< $(MAKEDEP) $(DEPFLAGS) $< %.o: %.C %.d @echo Compiling $< $(CC) $(MYOBJFLAGS) $(OBJOUPUT) $< $(OUTDIR)/%.so: %.o $(LNKOBJS) @echo Linking $@ $(LINK) $(MYLINKFLAGS) $(LNKOBJS) $(DSOOUTPUT) $@ $< # Include dependencies if they exist -include $(DEPFILES) clean: @rm $(OBJFILES) clobber: clean @rm $(DSOFILES) $(DEPFILES) $(TESTERSX) $(SHADERS) Then, if you type 'make' in that directory, it should build 'SOP_Flatte.so' for you (hopefully without any errors ). That's a very basic Makefile, but hopefully it gives you an idea of how the bundled makefiles could be used in a project. Cheers. Quote Link to comment Share on other sites More sharing options...
edward Posted January 27, 2009 Share Posted January 27, 2009 The makefiles in $HT/makefiles aren't that complicated. I recommend looking through them and understanding the basic set up and rules. In particular, it's important that you read the comments at the top of Makefile.gnu. FWIW, I just tried the following as a Makefile in $SHT/samples and it worked: DSONAME=SOP_Star.so # or SOP_Star.dll for Windows SOURCES=SOP_Star.C include $(HT)/makefiles/Makefile.gnu Now, all that is needed is: make The above Makefile is simpler than Mario's but in any reasonably sized project, you will want auto-dependencies of your C files. Quote Link to comment Share on other sites More sharing options...
edward Posted January 27, 2009 Share Posted January 27, 2009 if I runmake SOP_Flatten.C make: Nothing to be done for `SOP_Flatten.C'. This doesn't work because you're asking make to produce SOP_Flatten.C, which already exists. if I run make SOP_Flatten it doesn't find any of the $HT/include/ headers... This doesn't work since "SOP_Flatten" isn't a target. What you want is either "SOP_Flatten.dll" or "SOP_Flatten.so". Finally, it also can't possibly work if you just copy Makefile.linux without telling it something about what files to compile and what files to produce. Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted January 28, 2009 Share Posted January 28, 2009 This doesn't work because you're asking make to produce SOP_Flatten.C, which already exists.This doesn't work since "SOP_Flatten" isn't a target. What you want is either "SOP_Flatten.dll" or "SOP_Flatten.so". Finally, it also can't possibly work if you just copy Makefile.linux without telling it something about what files to compile and what files to produce. This is a good reference: http://www.gnu.org/software/make/manual/make.html Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted February 2, 2009 Share Posted February 2, 2009 This is a good reference:http://www.gnu.org/software/make/manual/make.html Speaking of Makefiles and their historical annoyances and limitations, are any of you guys using SCONS? http://www.scons.org/ I would love to see "make" go bye bye permanently. Mark Quote Link to comment Share on other sites More sharing options...
ivan Posted February 5, 2009 Author Share Posted February 5, 2009 BTW- Mario, I never properly thanked you for this. Very good of you to share! hugely helpful! Quote Link to comment Share on other sites More sharing options...
eloop Posted February 5, 2009 Share Posted February 5, 2009 Yep, I'm playing with scons at the moment. You have the complete power of python at your fingertips which is useful. If you look at the latest version of the HOT you can see I've got a SConscript file that builds the dso's (osx and linux, win32 not completed yet). I have a function in the script to grab the various compile options by running hcustom on a dummy file, then build a scons "Environment" and use it to do the building. The one problem at the moment is that scons is too smart in it's dependency tracking and thinks that it should always rebuild from scratch because sidefx's tagging mechanism is always changing one of the compile flags by placing the compile time in the tag. One way around it is to have a small source file, eg tag.C, that simply has the line "#include <UT/UT_DSOVersion.h>" and is compiled with the flag -DUT_DSO_TAGINFO=\"3262197....etc..., but have the rest of the source files compiled with an environment that doesn't use the taginfo. This minimizes the rebuilding while developing. It's also possible that CMake could be used to build dso's in a platform independent way, I'm currently doing a project that uses the InsightToolkit and OpenScenegraph, both huge libraries that use cmake for cross platform building. It's obviously very powerful but nowhere near as elegant as scons. If I was going to use it for hdk work I'd write a small python program to the same sort of thing as scons, ie run hcustom on a dummy file, grab the compile options and then stuff them into an cmake macro file. You would rerun the script whenever you changed houdini version or achitecture, something that could probably be automated. All this would be a lot easier if sidefx implemented my RFE to include a hdk-config tool ... -Drew Speaking of Makefiles and their historical annoyances and limitations, are any of you guys using SCONS?http://www.scons.org/ I would love to see "make" go bye bye permanently. Mark Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted February 11, 2009 Share Posted February 11, 2009 Yep, I'm playing with scons at the moment. You have the complete power of python at your fingertips which is useful. If you look at the latest version of the HOT you can see I've got a SConscript file that builds the dso's (osx and linux, win32 not completed yet).<SNIP> All this would be a lot easier if sidefx implemented my RFE to include a hdk-config tool ... -Drew Wow, great post. I looked at the scons script for the latest HOT, helpful as I;m just getting to know it. What did you have in mind for a hdk-config tool? Mark Quote Link to comment Share on other sites More sharing options...
eloop Posted February 11, 2009 Share Posted February 11, 2009 What did you have in mind for a hdk-config tool? Mark Eg $ fltk-config Usage: fltk-config [OPTIONS] Options: [--version] [--api-version] Options telling what we are doing: [--use-gl] use GL [--use-images] use extra image formats (PNG, JPEG) [--use-glut] use glut compatibility layer [--use-forms] use forms compatibility layer Options telling what information we request: [--cc] return C compiler used to compile FLTK [--cxx] return C++ compiler used to compile FLTK [--cflags] return flags to compile C using FLTK [--cxxflags] return flags to compile C++ using FLTK [--ldflags] return flags to link against FLTK [--ldstaticflags] return flags to link against static FLTK library even if there are DSOs installed [--libs] return FLTK libraries full path for dependencies Option to compile and link an application: [-g] compile the program with debugging information [--compile program.cxx] [--post program] I actually have something like this going now under linux, the plan is to use it for cmake building.So e.g. here is a CMakeLists for SOP_Star.C. cmake_minimum_required(VERSION 2.6) project(SOP_Star) # run our helper process to grab the compile and link flags from hcustom execute_process(COMMAND hython ${PROJECT_SOURCE_DIR}/hdk-config.py --cmake=HdkDefs.cmake) include(${CMAKE_BINARY_DIR}/HdkDefs.cmake) set(SOP_Star_SRCS SOP_Star.C) add_definitions(${HDK_DEFINITIONS}) include_directories(${HDK_INCLUDE_DIRS}) add_custom_command(OUTPUT sesitag.C DEPENDS ${SOP_Star_SRCS} COMMAND hython ${PROJECT_SOURCE_DIR}/hdk-config.py --tagfile=sesitag.C) add_library(SOP_Star SHARED ${SOP_Star_SRCS} sesitag.C) set_target_properties(SOP_Star PROPERTIES PREFIX "") Where the hdk-config.py command wrote the file HdkDefs.cmake as - set(HDK_INCLUDE_DIRS /opt/hfs9.5.303/toolkit/include /opt/hfs9.5.303/toolkit/include/htools) set(HDK_DEFINITIONS -DVERSION=\"9.5.303\" -DDLLEXPORT= -D_GNU_SOURCE -DLINUX -DAMD64 -m64 -fPIC -DSIZEOF_VOID_P=8 -DSESI_LITTLE_ENDIAN -DENABLE_THREADS -DUSE_PTHREADS -D_REENTRANT -D_FILE_OFFSET_BITS=64 -c -DGCC4 -DGCC3 -Wno-deprecated -Wall -W -Wno-parentheses -Wno-sign-compare -Wno-reorder -Wno-uninitialized -Wunused -Wno-unused-parameter -O2 -DMAKING_DSO -D__UT_DSOVersion__) set(HDK_LIBS -L/usr/X11R6/lib -lGLU -lGL -lX11 -lXext -lXi -ldl) The sesitag.C file looks like - // // Warning: do not edit, this file is written automatically by hdk-config.py. // #ifdef __UT_DSOVersion__ #undef __UT_DSOVersion__ #endif #define UT_DSO_TAGINFO "3262197cbf165b037af65da8542e94f02a5cd6b0917c87ce30f990485e46e4887b912bda9f4621614320e8ea67cb231c5afeef01f7d8ed5753042de86ec081ac5bbe45a0ff9249d6fa3c8d4c15ed08ecbb2e86a48aee9876f0" #include <UT/UT_DSOVersion.h> Then to get standard HDK code to compile, like SOP_Star.C, I always add the -D__UT_DSOVersion__ to make sure that the tag isn't defined in multiple object files. With some cleaning up this may be a useful community tool ? I may put it up on bitbucket and call for volunteers to do the windows port The python program could also be used used as a importable module for scons building similar to the HOT example. -Drew Quote Link to comment Share on other sites More sharing options...
eloop Posted February 12, 2009 Share Posted February 12, 2009 This is what it looks like at the moment ... $ python ../hdk-config.py --help Usage: hdk-config.py [options] Options: -h, --help show this help message and exit -C CMAKEFILE, --cmake=CMAKEFILE write out the compile defs to a cmake package module -T TAGFILE, --tagfile=TAGFILE generate a C++ file with a sesitag defined, ie no need to compile -DUT_DSO_VERSION --cxx return C++ compiler used to compile HDK --cxxflags return flags to compile C++ using the HDK --ldflags return flags to link C++ using the HDK --g compile the program with debug information --notag do not include the UT_DSO_TAGINFO in flags $ python ../hdk-config.py --cxxflags -DUT_DSO_TAGINFO=\"3262197cbf165b037af65da8542e94f02a5cd6b0917c87ce10f990485e46e4887b912bda9f321d7c1646cbed25da200e4bffe40afbd1e35442162fe867f3abac5bbe45a0ff924994e17f970847fe43abb25ec5da\" -DVERSION=\"9.5.303\" -DDLLEXPORT= -D_GNU_SOURCE -DLINUX -DAMD64 -m64 -fPIC -DSIZEOF_VOID_P=8 -DSESI_LITTLE_ENDIAN -DENABLE_THREADS -DUSE_PTHREADS -D_REENTRANT -D_FILE_OFFSET_BITS=64 -c -DGCC4 -DGCC3 -Wno-deprecated -I/opt/hfs9.5.303/toolkit/include -I/opt/hfs9.5.303/toolkit/include/htools -Wall -W -Wno-parentheses -Wno-sign-compare -Wno-reorder -Wno-uninitialized -Wunused -Wno-unused-parameter -O2 -DMAKING_DSO -Drew Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted February 12, 2009 Share Posted February 12, 2009 Right, I see. Yea, this would be very helpful. Any response from SESI? Seems like it wouldn't be too difficult to do. Mark Quote Link to comment Share on other sites More sharing options...
