Casting shadow on i3d
chang
If i3d texture was not generated from metaballs,
than the size of 3d texture would usually be a little bit larger
than the size of the object it was made off.
That is why you can loose details if you assign
this shader to the object directly.
If it has happened you could use the following scheme:
"Source of i3d" SOP -> Box SOP -> XForm SOP (scale a litle bit) -> Shader SOP
Hi Chang
Really cool looking clouds, i didn't quite understand
AndrewVK explaination of how to get the clouds casting shadows
a hipc file of the cloud torus would be very helpful, i am trying the same type of effect and can never get my clouds to cast shadows either.
Later
Ben
Still there are some limitations...
The standard 3D Texture Cloud "surface" shader works incorrectly
in case if "Object Inside Cloud" (because of Z-Sorting).
3D Texture Fog "atmosphere" shader does not have this limitation,
but it cannot cast shadows. :(
IMHO:
I think it is possible to rewrite the shader
to handle "Object inside" and/or/both "Camera inside" situations,
though it would work slower.
  • 2 years later...
  AndrewVK said:
I think its imposible with 3D Texture Fog "atmosphere" shader
because atmosphere shader is carried out
after surface shader has finished.
Try 3D Texture Cloud "surface" shader.
5871[/snapback]
Hello,
How did you do the cloud with surface shader. To what must you connect the surface shader if there is no Atmosphere node. I don't get my shadows like in the example picture.
Any help is welcome.
thx
  AndrewVK said:
Here an example  :)
Houdini 8.313
20056[/snapback]
Thanks AndrewVK for the scene file. Now I understand the set-up.
I must say this Houdini forum is top-notch, with helpfull and friendly people. Maya users , eat your heart out. Houdini rocks!
Thanks, thanks , thanks...
bernard
bernard
20057[/snapback]
Hello,
How can I cast shadows ON the cloud (example: like cloud behind a wall -see pictures from chang)
thx,
bernard
I have no such an experience..but i am 100% sure...PCloud will work just fine
without I3D at all. Better or no...i dont know...but faster :)
Especially after new functions for work with metaballs have appeared.
metamarch...metaimport...metaweight etc.
