Number of points / vertices in primitive?
Hi guys,
I need a method that returns the number of points or vertices in primitive (precisely GEO_Primitive) and also a way to get a reference to any point / vertex in a prim.
I'm stuck somewhere between those Doxy HDK pages trying to figure out this stuff :(
Thanks.
Edited by hoknamahn
Culled from one of my sops ...
	  const GEO_Primitive *prim;
	  FOR_ALL_PRIMITIVES(gdp_in,prim)
		  if (prim->getPrimitiveId()==GEOPRIMPOLY)
			  if (prim->getVertexCount() >= 3)
I generally just browse the include files, quicker than loading web pages.
-Drew
Hi guys,
Thanks.
Edited by eloop
-Drew
Thanks Drew!
Looks like the best way is digging of someones code :D
  • 7 months later...
Thread resurrection!
Instead of opening one I'm just gonna bump this, but I''m trying to do the same business, except I want the total number of points, since I'm not working with vertices, and I cannot seem to be able to find a way.
I tried something like this but ended up getting this crazy value.
    FOR_ALL_GPOINTS(gdp, pt)
        numpoints += pt->getNum();
Been searching all over the docs, but can't seem to find anything that works.
pt->getNum() in the above code gives you the point number (ie. $PT) so you don't want to be adding those up. It would simpler if you just added 1 in your loop to numpoints to get the total number of points that the FOR_ALL_GPOINTS() loop iterated over. However, since you're looping through ALL points, you can just do
numpoints = gdp->points().entries()
(without looping)
(without looping)
Ack, I knew I shouldn't have been coding so late. Thanks edward!
