Apprentice 6 COPs v2
I tried to open the file but I got a ton of errors:
Not enough elements found for parameter "point1" etc
and the rotospline seems broken for some reason...
sorry I couldn't help
edit-
I changed the rotospline|Image Tab from Add Plane = none to Add Plane = C, A (C:RGB, A)
and this is my result:
here
If you're simply asking why the alpha is pixelated, then you can simply turn off the A button under Plane Scope in the Bright COP's parameter pane ...
There does however seem to be cooking problems when trying to brighten the alpha plane using the mask.
