generating an environment map
I'm trying to composite a sign that I built and animated on to a building in a still. I'm struggling with tryin to light the sign properly. I want to try global illumination with an environment map. However, I don't have a proper HDR image. I just have this still. Is there a way to create a decent environment map from the still I have?
chris_sign_simple_comp_v02_resize_back.hipnc
render_from_SOP.zip
It looks like a pretty ambient/murky day. I'll bet you could just throw together a latlong env map using sampled colors from that sky, a darker gray ground plane and you'd get pretty close. There is no cloud detail nor bright sun direction.
as jason mention I think its more to do with light match then env map, give atry and see.
cheers
junaid
