hatrick Posted May 29, 2009 Share Posted May 29, 2009 hi, could please someone update the wikientry for the zbrush houdini workflow to current versions (H10 and Zbrush3) ore give me little explanation. I coudnt find the right commands in z brush for example "addaptive" in tools a.s.o. would be great if someone could help me out thanks a lot greets HT Quote Link to comment Share on other sites More sharing options...
theflu Posted May 30, 2009 Share Posted May 30, 2009 (edited) hey, i have good results with 32bit, adaptive disp maps (smoothed).beeing new to houdini, i was really surprised by how good mantra renders displacement. (dont forget to adjust the dicing of your geometry) hope this helps. (the only thing i coulnt find out is how to mix a bump with the disp so i layered the bump in ps into the disp maps, until i understand the vex stuff better Edited May 30, 2009 by theflu Quote Link to comment Share on other sites More sharing options...
hatrick Posted May 30, 2009 Author Share Posted May 30, 2009 hi, thanks for the tips but my problems are more on the z bruh side...may you can give me some tips how to setup and export the displacementmaps in z brush for houdini thx Quote Link to comment Share on other sites More sharing options...
theflu Posted May 30, 2009 Share Posted May 30, 2009 (edited) hi, thanks for the tips but my problems are more on the z bruh side...may you can give me some tips how to setup and export the displacementmaps in z brush for houdini thx hey, in zbrush under the tool palette, theres a displacement tab. so if your model has got uvs, put the resolution to your desired size 2or 4k maybe, press adaptive, and smoothuvs and hit create map. then go to alpha menue, your created map will be there, hit the DE options, there your can enter a quick code, you find them on zbrushcentral, i entered the code i also use for vray in c4d thats 32 bit Greyscale: DE-JCGK-EACADA-4D_D32 then i export the map. and it works very nice for me in mantra, hope this will help you. ulf Edited May 30, 2009 by theflu Quote Link to comment Share on other sites More sharing options...
LEO-oo- Posted May 30, 2009 Share Posted May 30, 2009 @theflu Thanks for the hints! Hopeful there will be a H-version for GoZBr soon! Quote Link to comment Share on other sites More sharing options...
theflu Posted May 30, 2009 Share Posted May 30, 2009 @thefluThanks for the hints! Hopeful there will be a H-version for GoZBr soon! i hope so too, saw it this morning, awesome plug! Quote Link to comment Share on other sites More sharing options...
LEO-oo- Posted June 1, 2009 Share Posted June 1, 2009 @theflu Any experience with the plug-in - you tried it with C4D? Quote Link to comment Share on other sites More sharing options...
