Reflection Occlusion
Korhon
Hi!
I was wondering if anyone managed to do reflection occlution with mantra?
Is this something that can be done with vops?
I found this a older thread about this, but it only explains a cheat, and a way of doing it with code. ( and i dont know how to write shaders )
This thread show what i want to do.
http://www.illuminatelabs.com/support/tuto...tive-occlusion/
you have the ability to specify direction vector (N) for the occlusion VOP
so you can plug there a reflect VOP with normalised I and normalised N as inputs
you will not have control over sample spread however, so its use is limited
if you want spread control you probably need to use gather loop
or does anybody know an easier solution?
Edited by anim
Thanks for the fast reply!
I tried it and it works as you described. :) But im in need of a crisp reflection occlution pass.
So if anyone have some way of manipulation the spread let me know :)
  Korhon said:
Hi!
This is perfectly doable in Mantra and VEX. There are number of similar approaches to reflection occlusion. One can ask how to deal with self reflections in such case and so on. I'm not in this topic by any means. But anyway, quick try of the way from your link in vex - definitely incomplete...
surface
   reflectionOcc(string map="";
			   float angle=.25;
			   int samples=32)
	   string name = "";
	   float occ = 0;
	   vector bend = 0;
	   vector nN = normalize(N);
	   // Scope to this object:
	   renderstate("object:name", name);
	   // Env reflections:
	   vector d = reflect(normalize(I),nN);
	   vector env = environment(map, d, "envobject", "space:world");
	   // Compute occlusion:
	   occlusion(occ, bend, P, d, "samples", samples, "angle", angle, "scope",name);
		Cf = env * (1-occ);
Save it to *.vlf file and use command: vcc -l myfile.otl myshader.vfl
cheers,
skk.
EDIT:
showtime!
Edited by SYmek
Wow thanks for the reply!
Will try it out now!
I was also thinking of making a reflective shader that reflects a white enviroment and itself as black. Wouldnt that work pretty well for a reflection occlution pass?
But im now sure on how to make it reflect itself black.
That would work too. The occlusion() call is quite a bit faster than the reflectlight() call because it doesn't have to evaluate the color of the surface it strikes (well, only opacity if you explicitly tell it to).
Gosh. I feel stupid, I completely missed that part. Sorry :blush:
I think you could use fastshadowVOP to mimic occlusion with control over cone angle in vops. It could be even faster then occlusion, except you can't use irradiance cache to accelerate it (like in case of occlusion()). Just mult it with environmapVOP.
skk.
Edited by SYmek
