copy SOP and orientation
There are two ways to do this.
a. If the circle is at the origin, you can put down a Point SOP, Add Normals & set the Parameters to $TX, $TY, $TZ.
b. If the circle is not at the origin, you can scale down the circle slightly using, for example, a Primitive SOP, put down a Point SOP, connect the original circle to the first input & the scaled down one to the second input of the Point SOP. Again, turn on Add Normals & set the Parameters to $TX - $TX2, $TY - $TY2, $TZ - $TZ2.
I've attached an example hip file.
Cheers!
steven
circle_normals.zip
