MENOZ Posted August 15, 2009 Share Posted August 15, 2009 hello. Do you know a method to generate millions of particles at rendertime given a low number of particles? what I mean is trying to duplicate partilces or make others particles that follow the motion of surrounding paritlces, but without display them in viewport, and generate only at rendertime. I remember that I read something on surf's up paper, for generate the waves splashes, but that was a little too advanced I think.. thank you! Quote Link to comment Share on other sites More sharing options...
beeemtee Posted August 15, 2009 Share Posted August 15, 2009 hi, while it's not a ready to use solution, you can get some ideas here: http://s204357084.onlinehome.us/project/dataExpansion_1/dataExpansion_1.html check the other two parts of the story too. cheers bmt Quote Link to comment Share on other sites More sharing options...
symek Posted August 15, 2009 Share Posted August 15, 2009 hello. Do you know a method to generate millions of particles at rendertime given a low number of particles? what I mean is trying to duplicate partilces or make others particles that follow the motion of surrounding paritlces, but without display them in viewport, and generate only at rendertime. I remember that I read something on surf's up paper, for generate the waves splashes, but that was a little too advanced I think.. thank you! http://www.digitalcinemaarts.com/dev/clusterThis/index.html With the help of this dso, you can render 50million of particles on average machine in one pass. It works great though last time I've checked there wasn't too much control on particles distribution. Cvex might be an option but afaik ClusterThis still has some limitation here (access to parent attributes). Still even without that extension, you can achieve nice results playing with 2 or 3 milion of particles. Carefully chosen size, opacity, and motion blur for particles can greatly helps here. cheers, skk. Quote Link to comment Share on other sites More sharing options...
mrice Posted August 16, 2009 Share Posted August 16, 2009 It works great though last time I've checked there wasn't too much control on particles distribution. Cvex might be an option but afaik ClusterThis still has some limitation here (access to parent attributes). I was looking at the latest version recently and cvex seemed to be working well, although I dont think there is way to generate a unique id per instance yet. Quote Link to comment Share on other sites More sharing options...
MENOZ Posted August 20, 2009 Author Share Posted August 20, 2009 (edited) hello, I tried using the DSO, but when I try to render the take 11 particle point instancing, for example, I get this error. Unknown operator type: Shop/pcplastic Unknown operator type: Shop/sfsss Unknown operator type: Shop/fastgi Generating Image: ip (720x486) Plane[C]: Cf+Af[4] (16-bit float) SampleFilter: alpha PixelFilter: gaussian 2 2 VEX Type: vector4 Dither: 0.5 Gamma: 1 Gain: 1 White point: 1 mantra: Unable to find registration function 'allocProcedural' in 'mantra/VRAY_clusterThis.so' mantra: Cannot allocate procedural 'clusterThis' on object /obj/particles Load Time: 0.468u 0.453s 0.57r Memory: 47.22 MB of 47.36 MB arena size. VM Size: 187.80 MB VEX Shaders Loaded op:/obj/shopnet/screening/gridSurface stdin.vex Thread Count: 2 Render Time: 0.859u 0.578s 1.24r Memory: 70.80 MB of 71.81 MB arena size. VM Size: 269.25 MB Could you help me please to solve this problem? it seems it search 'mantra/VRAY_clusterThis.so' but I am on win, not linux, so I use the .DLL file instead of .so EDIT: i added the VRAY_clusterThis.so in the directory, and now when i render it prompt me an error mesage from mantra.exe, then a houdini DSO error. (193)couldn't load .../VRAY_clusterThis.so. this is probably beacuse this file was intended for use with a different version of Houdini I have the lastest build, but in the readme it taks about H 9.5. the problem still remain Edited August 20, 2009 by MENOZ Quote Link to comment Share on other sites More sharing options...
MENOZ Posted August 22, 2009 Author Share Posted August 22, 2009 (edited) anybody could help me please?? Edited August 25, 2009 by MENOZ Quote Link to comment Share on other sites More sharing options...
MENOZ Posted August 25, 2009 Author Share Posted August 25, 2009 mantra: Unable to find registration function 'allocProcedural' in 'mantra/VRAY_clusterThis.so' what does this mean? where is the problem? I can't solve this Quote Link to comment Share on other sites More sharing options...
Ratman Posted August 25, 2009 Share Posted August 25, 2009 It means it can't find the correct file it needs, for the release you need to use win32 for 9.5, since it's compiled for that. You need to place the VRAY_Procedural on $HOME/houdini9.5, the .dll in $HOME/houdini9.5/dso/mantra. I've got a compile for Win64 in Houdini 10, but I'm still testing to see if it works completely. Quote Link to comment Share on other sites More sharing options...
MENOZ Posted August 26, 2009 Author Share Posted August 26, 2009 It means it can't find the correct file it needs, for the release you need to use win32 for 9.5, since it's compiled for that. You need to place the VRAY_Procedural on $HOME/houdini9.5, the .dll in $HOME/houdini9.5/dso/mantra. I've got a compile for Win64 in Houdini 10, but I'm still testing to see if it works completely. the problem probably is that I'm using Houdini 10. the paths are correct. Quote Link to comment Share on other sites More sharing options...
CeeGee Posted September 17, 2009 Share Posted September 17, 2009 It means it can't find the correct file it needs, for the release you need to use win32 for 9.5, since it's compiled for that. You need to place the VRAY_Procedural on $HOME/houdini9.5, the .dll in $HOME/houdini9.5/dso/mantra. I've got a compile for Win64 in Houdini 10, but I'm still testing to see if it works completely. Hi Ratman any news on Houdini 10 x64 build... Quote Link to comment Share on other sites More sharing options...
Ratman Posted September 17, 2009 Share Posted September 17, 2009 Hi Ratman any news on Houdini 10 x64 build... I knew I'd forgotten something, sorry about that, I've had a busy couple of days. Everything else should work except for your old DLL, replace it with the one I compiled, it's compiled for h10.0.374, I'm sticking with Production builds for now unless someone really needs one for a daily build. Let me know how it works out for you! VRAY_clusterThis_h10.0.374.zip Quote Link to comment Share on other sites More sharing options...
CeeGee Posted September 18, 2009 Share Posted September 18, 2009 Thanks Ratman. Quote Link to comment Share on other sites More sharing options...
bhaveshpandey Posted September 18, 2009 Share Posted September 18, 2009 (edited) err....anything about the win 32 bit?? its really unfortunate that its not supported on H10.. It's a very useful tool indeed. Edited September 19, 2009 by bhaveshpandey Quote Link to comment Share on other sites More sharing options...
baobao Posted September 21, 2009 Share Posted September 21, 2009 Hop it for H10 early Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted September 24, 2009 Share Posted September 24, 2009 Greetings, Sorry, been way distracted with other work, haven't seen this thread yet (I think) but wanted to post that there is a new version about ready to roll out, shouldn't be too much longer. It will have the curve instancing working and a few other goodies/optimizations. Mark Quote Link to comment Share on other sites More sharing options...
Ratman Posted September 25, 2009 Share Posted September 25, 2009 Greetings, Sorry, been way distracted with other work, haven't seen this thread yet (I think) but wanted to post that there is a new version about ready to roll out, shouldn't be too much longer. It will have the curve instancing working and a few other goodies/optimizations. Mark Thanks for the heads up, Mark! Should be good. Quote Link to comment Share on other sites More sharing options...
