Gradual Visibility
Is there a way to turn the visibility of my SOPs off gradually, like a fade out effect.
I've tried the visibility SOP but it only accepts 0 or 1 input and nothing in between, so can't be animated via CHOPs.
Any help greatly appreciated.
You could put a point SOP down and animate the alpha... I guess...
Without a better description of what you're trying to do then its hard to say. There are probably a few methods you could use.
Cheers
Marc
:D
Marc,
I've tried the point SOP and alpha animating but didn't yield any results.
Basically I have a bunch of cells tumbling down a tube and like to fade them out, now that's the easy part via $AGE since their copied to particle system, but not my tube, which I also want to fade out gradually.
Cheers
Andre
