3d multi tex projection
itriix
Hello everyone... Has anyone played around with getting a 3d multi texture projection working?
Example:
A 3D model of a building. I would like to say project some brick texture onto the building. However, I would like it to be seemless at the edges, all the way around the building, as it should for this example. In renderman, we used a custom 3d multi texture node that would project the texture from each axis and then correctly fade between the projections when needed based on the angles of the geometry. I'm not very sure how in houdini to do something like this.
thanks!
Jonathan
Edited by itriix
Example:
thanks!
Jonathan
multiple UV sets, one from each angle in SOPs.
make a vector attribute which is the projected direction in SOPs. (or a parameter on the shader)
in the shader look up each texture for each uv set.
mix between them with the dot product of the normal and projection direction.
Never done it before, but that might work?
Hiya, my perpetually work-in-progress ubermaterial has a "triplanar/implicit cube map" mapping option, which
does pretty much what you describe, but does not do the blending. In fact, that's a nice idea, I think I'll steal it ;)
sam.h: a SOP solution is not as good in a general case, doing it "per-pixel" in the shader works better
(but of course uses a few more cycles..)
eetu.
hello everyone, thanks for all of your help!
sam.h, thank you so much for your suggestion. i'd have to agree with eetu however that this should be done in the shader
eetu, awesome! i can't wait until you implement it into your ubershader :)
mrice, thanks so much for the example. i'll give it a look tomorrow when i wake up :)
thanks one more time,
Jonathan
Edited by itriix
  • 1 month later...
  • 2 weeks later...
Hi everyone,
i've been revamping the "blended_boxmap* hip file from mrice...
There were a few things that seemed to need some fixing :)
It was missing a "y_dir" dotproduct... section in the network, which would then be mixed in with another colormix node.
another thing... right out of the box, if I applied it to a cube... with a brick texture. the bricks on the x and z plane were not the same... instead the x and y plane bricks matched up... if you are doing a wall however, this won't work. and so, the ability for the user to "rotate" the x, y and z, texture, was added :)
also a scale param... to scale the texture up and down *uniformly*
lastly i discussed the idea with a friend of mine *who has a lot more experience with this than i*, and he said there were a few things that could be trimmed out... so i did that too.
I'm also in the process of finding out if I am doing the "transform matrix" correctly. Then, once this is all working, i'm going to hook it up with displacement :)
Here is a test on a sphere and cube...
On the Vop Vex Surface Shop, just change the texture map to a repeating texture *brick*
Tweak the Edge blend param, to get a different falloff
Rotate the Texture around a particular axis if you need to
Scale it also if you need to do that
Jonathan
**EDIT** The pic of the sphere is in fact the wrong pic, look at the next post for a better one of that
3d_Multi_Tex.hip
Edited by itriix
ehhh, can't wait till the "full editor" is up and working again... noticed I uploaded the wrong sphere....
here is a better one :)
(anyways, this is a good time to point out, that's what happens when you change the edge blending ramp) on the vop vex surface shop node!
It also shows, that i think there can be a bit more tweaking to fix it perfectly up....
And, if anyone could look at the hip file and let me know if they see anything wrong in there :) that would be awesome too
Edited by itriix
  • 6 months later...
